Reset questions...
Old Apr 16, 2011 | 07:31 AM
moosehunter's Avatar
moosehunter
Default Reset questions...
I have two questions;
First, yesterday I went to the garage and the mechanic forgot to reset the oil change light and now I'm out of the area. Anyone know an easy way to reset it?
Second: I just installed after market rims and tires and not the tire pressure light message won't stop lighting up everytime I start the truck. I'm not interested in buyIng $400 gadget to put on the new rims but was wandering if it could be deactivated?
Thanks
Old Apr 16, 2011 | 07:40 AM
seawind3000's Avatar
seawind3000
The oil is easy, turn on the key (don't start the engine) wait for the warning lights to off,(some will stay on.. eng oil ect) push the gas peddle to the floor 3 times in 10 seconds and your done.
The TPM requires a small piece of black tape.
Mike
Old Apr 16, 2011 | 08:36 AM
moosehunter
Thanks Mike
Old Apr 16, 2011 | 09:52 AM
BigBlueEdge's Avatar
BigBlueEdge
When then installed your new rims did they either move the pressure sensors from your stock rims or install new ones? If so, there is probably just some re-learning procedure that needs to be done. If not, nothing is going to remove the light except getting sensors installed.
Rob
Old Apr 16, 2011 | 11:06 AM
moosehunter
Thanks Rob
Old Apr 17, 2011 | 02:36 AM
TDTIPMO's Avatar
TDTIPMO
I'm guessing they didn't install new sensors in the new wheels. Otherwise they should recalibrate on their own.
Old Apr 17, 2011 | 01:10 PM
moosehunter
Nope didn't install sensors and now I got rid of the stock rims and no more sensors so basically out of luck...
Old Apr 18, 2011 | 04:45 AM
TDTIPMO's Avatar
TDTIPMO
You can still install the sensors, any tire shop will do it. That would be my choice. Other wise you're going to have the TPMS chime every time you start your truck. Plus it's just nice to have. Might cost you around $100 or so, but I think it'd be worth it.
Old Apr 18, 2011 | 10:29 AM
moosehunter
Can I get those sensors after market? Or do I have to buy them at the dealers?
Old Apr 19, 2011 | 12:18 AM
TDTIPMO's Avatar
TDTIPMO
I've heard of people buying them aftermarket, but if you just went to a tire shop they would probably have them. After I got to thinking about it, you'd probably have to get your tires rebalanced afterwards so it will probably be more than $100 with the sensors and the remount and balance. It can't be that expensive though.
