Dodge Recall K36 (2011 1500's)
Old Jun 28, 2011 | 08:25 PM
freq's Avatar
freq
Default Dodge Recall K36 (2011 1500's)
REAR AXLE FLUID DRAIN-BACK FLOW RESTRICTOR
Did anyone get this done? Just did a search based on my VIN and even though I just picked it up from the dealership on Saturday, it was listed as incomplete!
Also, is there a way to search RRT's and see if they apply to your Yr Model?
Thanks
Old Jun 29, 2011 | 12:46 AM
72combo's Avatar
72combo
Call the dealer give them your vin
Old Jun 30, 2011 | 12:03 AM
brettj2408's Avatar
brettj2408
since your year is the first without a drain plug on the rear differential cover they machinced the fill plugs too low so in an earlier RRT they had you adding an extra 20oz of gear lube filled through the vent tube. now they came out with a recall with a new differential cover with a fill plug on it, and also having a pinion flow restrictor installed
Old Jun 30, 2011 | 12:59 AM
freq's Avatar
freq
Thanks for the clarification!
Anyone on this?
Old Jun 30, 2011 | 08:55 AM
WaySlowWhitey's Avatar
WaySlowWhitey
Just had mine done two weeks ago. In and out with a new cover and fluid.
Old Jun 30, 2011 | 08:57 AM
WNDERR's Avatar
WNDERR
Had mine done a couple weeks ago ---- and, dealers are supposed to do any recalls, before they release a new vehicle............... just sayin!
Old Jun 30, 2011 | 08:46 PM
freq's Avatar
freq
That would make sense, right?
Old Jun 30, 2011 | 09:23 PM
lxman1's Avatar
lxman1
Site Moderator
The service dept can pull up your VIN and any recalls/TSB's will show up. Just have them have a look-see when you get the rearend fixed.
Old Jul 1, 2011 | 05:12 AM
freq's Avatar
freq
Will do.. also, this will be my first time in to the service department for a vehicle EVER (always use outside shops and never have had a warranty ;x )
Someone said that I can pull up a build sheet(?) and some other paperwork? Any ideas as to what paperwork I should ask them for? I went to the owner's part of dodge.com and the only service history listed was at 4500 miles for an oil change and to add accessories(executive demo).
So, build sheet and service history is what I ask for? And what else? RRT list (if that's even a reat thing)?
Old Jul 1, 2011 | 08:44 AM
RAMULAK's Avatar
RAMULAK
In light of recent events you might want to have them check that pinion nut people seem to be having trouble with. Or maybe this recall is just a ruse to get people to bring their trucks so they can check it before the rear end fails.
Had to wonder myself why I had to have my diff oil changed out so early. I was getting emails telling me to come in for that every few days. Now almost a year later no emails for the diff oil changes? What do ya know.
