Fog lights
Speaking from past experience with this (having done it on my Trailblazer VIA a relay) I would avoid doing this. Not throwing a roadblock your way, just looking out thats all.. If your truck is under warranty, and anything even remotely electronic happens, DODGE will without a doubt, point the finger at any sort of mod in this arena...With that said, i was in the same situation and wanted more light. I used a dodge forum promo code( dont remember off hand) and bought some HID replacement bulbs from Go Recon, and replaced highs, lows, and fogs. The light output of my highs is very bright to the point I dont need the fogs to come on...
I do know there is a mod though, because you can hold the turn signal in the back position and all 4 lights come on..
Short answer is probably no. I am not a 4th gen expert by any means, but on most modern vehicles lights etc are no longer controlled by the switches... the switch talks to the (usually BCM) computer via the CANBUS which talks to the (for lack of a better word) relay that runs the lights.
What lights do what when is controlled in the software. You can probably hack the software to do whatever you want... jerryrigging it wit jumpers is not the way to go.
Evidence: your lights staying on for an amount of time you set in the DIC after you shut your truck off/ The way your marker lights come on when you use remote start/ The way your lights come on when it gets dark.
I see that you are from canada. You run into a road block right away. It is illegal to run your fogs with your high beams, don't ask me why because it does not make sense to me. But I assume it has to with others not being able to tell if your high beams are on or not. But again I have no idea why its just illegal.
Others are correct here, everything is run through the canbus. You "Could" go to the dealer and see if they can switch it for you. Doubt they will because of what I stated above. I would not even advise doing any relay work or rewiring. This system is so sensitive that if it detects one thing wrong, you could be looking at some serious computer messups.
BUT I do have an easy solution, thats coming in the near future. The answer is bullydog tuners. Bullydog is strictly associated with dodge so it has many different features at the click of a button. Things like disabling seat belt minder, or how long your truck goes till the minder comes on. Disable driving lights. And yes turning the fogs on with the high beams.
The only issue right now is bullydog does not have a tune released for the 2011 rams yet. I am waiting on a reply to when that would be. But thats your easiest way to do it without voiding the warranty and having unnecessary wiring.
Hope this helps
Hope this helps
I should mention too that there is not a 100% guarantee that they will provide the same functions on the tuner GT Gas for the 2011s. They have had them for the rams 06-09 (I had used these functions on my 08) I just assume that they will have the same functions because dodge still uses the same type of computer.
Trending Topics
Not sure about the 4th Gens but the TIPM 3rd Gens ('06+) the country code can be changed under the lights option with the StarScan tool. Depending on country chosen, you will get daytime running lights on/off and fogs on with high on/off. You just have to find the county with the right combination of the two you want.
This would not void warranty obviously since only a dealer has the StarScan (well I have access to one and it's not at a dealer, LOL).
Some dealers will do this for free, some for a fee and others won't touch a country code setting for outside the country you are in for "legality reasons", just depends on the dealer.
On pre-TIPM models you can just run a wire from the high beam relay to the fog light relay...
