4x4 3.92 rear
Old Nov 9, 2011 | 10:14 AM
  #21
depunz's Avatar
depunz
I've never seen above 16 with mine. Of course, I've never had it on the interstate farther than 50 miles or so and even ion the interstate in WV there are no flat stretches. I've had 245/70/17's up to 285/70/17's and it really made no difference in my fuel economy.
Old Nov 10, 2011 | 03:39 PM
  #22
70GS455's Avatar
70GS455
I have 3.92's. I would rather have 3.55's. I don't tow very often or race it.
On the interstate at 70-75 mph, i usually get 17-18 mpg
Old Nov 10, 2011 | 04:03 PM
  #23
roadrnnr's Avatar
roadrnnr
Wow never heard anybody ever say that.
Does the 09 have the MDS system?
Old Nov 10, 2011 | 05:48 PM
  #24
Pedro Dog's Avatar
Pedro Dog
Yes the do have the MDS. I have the 09 CC with the 3.21 axle. We have a property in the mountains but live by the ocean. On the way there the lie-o-meter says we get close to 20 MPGs but hand calculated it's usually about 1 MPG less. On the way back we get closer to 21 on the lie-o-meter but hand calc about 20. This is all highway but sometimes leaving the city we get some traffic and that hurts the MPGs some. I usually like to pass freely and then set the cruise control to at least 75 MPH. When my wife drives the truck, she drives closer to 70 and gets about 22 MPG on the lie-o-meter. Around town with lots of stop and go it closer to 13 MPG. The truck is completely stock. The drive each way is 330 miles.
Old Nov 10, 2011 | 11:13 PM
  #25
HammerZ71's Avatar
HammerZ71
Originally Posted by learle73
very interesting! I have driven a few 3.55's but have not driven the 3.92 yet. I am very surprised that someone has said that the 3.92 will do better around city driving. I am in Mobile, Al. and the city driving is horrible. I get 13 miles a gallon in my V6 Dakota. Is it a much more noticeable difference with towing. I realize it makes the truck go from an 8550 capacity to 9950.
Of course city MPGs should increase, you require less throttle to achieve the same RPMs, so unless you like the feel of the new gearing and "get on it" harder than before, you should see a modest fuel economy increase.
Originally Posted by Ram_EK
How come I was advised by our local RAM dealership that front and rear axle ratios don't have to be the same???
Me not using 4 Wheel drive is like asking the pope not to pray
I am really confused now as my RAM, and according to this same dealer, originally came with 2 different axle ratios
It's perfectly fine to have two different ratios in the front and rear axles - long as you don't ever put it in 4 wheel drive. If you do, you'll need to have the flatbed driver go back for your transfer case, axles and parts of your carrier off the middle of the road AFTER he winches your truck up!
Whoever you are talking to at the dealership seriously needs to find another line of work. My 14 year old niece knows you can't have different axle ratios front to rear on a 4x4!
It's a 2011 Ram 1500 Quad Cab SLT 4x4 HEMI 5.7, 5speed Auto transmission and 17" rims.
I was told that my front diff was a Chrysler 9.25" & @ the rear I had a Chrysler 10.50". I did some research and found out that the Chrysler 10.50" had 14 bolts, while mine has 12 bolts that I counted....Weird!!! Can't I type my vin number somewhere and have the list of equipment popping out?
Either you are very confused or it's time to find a new dealer and report this one to Chrysler/Fiat and have them shut down!
First of all NO 1/2 ton truck comes with a 10.5" rear axle. Secondly, the Chrysler Corporate (AAM) axles were not used after the 2010 models as Ram switched to ZF for their axles, but sizes still remain 9.25", 12 bolt, 31 spline. The front is an 8", 10 bolt, 29 spline.
The ONLY 1500 series to have a 10.5" rear axle is the MegaCab. Also, there is NO dealer option to order a half ton Ram with an axle ratio other than 3.21, 3.55 or 3.92, they can not order you a 2011 half ton 1500 Ram with 4.10 axles from the factory.
Originally Posted by WaySlowWhitey
RAMs were offered with 3 ratios, 3:55, 3:73 and 3:92. You chose one which matched both the front and rear in a 4x4. I believe you are being far too literal.
The front housing is likely only big enough to fit a 3:92 while the rear can fit a 4:10. That said, the front a rear need to match which leaves you with the ability to only go so low as a 3:92.
Actually Rams are offered in 4 ratios. 3.21, 3.55 and 3.92 in 1500 IFS trucks, 3.73 & 4.10 in 1500 SFA (MegaCab) and 2500/3500 trucks.
Not sure of the ZF carrier but I know for a fact that the 2009 & 2010 1500s with AAM axles could handle up to 4.88 in the rear and 4.56 in the front housings which would mean max for a 4x4 would be 4.56s...
Old Nov 11, 2011 | 04:46 PM
  #26
Ram_EK's Avatar
Ram_EK
Well then I guess I should have ZF axles in my truck...Can't we just put the vin number somewhere on the web and get "The" list of equipment the truck came out from the factory with?
Anyway the dealer announced that as of next week, the parts I ordered will start arriving
Mopar Ram Runner body kit + stage one 3.5" suspension lift kit + the famous 4:10.1 axle ratios + Pro Comp Black 17"x9.5" rims + 35x12.50R17 BF Goodrich MT KM2.
I will take a few pictures of my front and rear diffs and upload them here, hoping that you guys could identify them for me, coz if they can't both hold the 4:10.1 ratios, this means that either they took me for a dupe and will be installing 3:92.1 ratios, or after market parts that are not original...
Both cases I will be f....d
Thank you all for your help
Old Nov 11, 2011 | 08:25 PM
  #27
53fireman's Avatar
53fireman
I have the same setup, 2011 with the 5.7, 3.92 gears, 4x4, LSD, brake controller, 17" wheels, stock tires... and my average on the EVIC is about 14.5 MPG. About half and half highway/around town...
Old Nov 12, 2011 | 07:43 AM
  #28
HammerZ71's Avatar
HammerZ71
Yes, you can go here and ask for a build sheet:
http://www.dodge.com/webselfservice/...m%28%27R%27%29
You can also request one from your dealer and they can print it on the spot...
Old Nov 12, 2011 | 09:39 AM
  #29
Ram_EK's Avatar
Ram_EK
Many thanks dear HammerZ71 I got the specification sheet printed, and I got a picture of the rear diff wide open as well...It's a 12 bolts is for sure
Usually there should be a tag or something on the diff covers, mine has nothing at all
DRNS 235mm rear axle which is 9.25" like you guessed, and DJMS 205mm HD front axle which is 8". DS7S Conventional Differential Frt Axle.
Is it a ZF, an AAM, nobody knows
Nothing written about the ratios on that paper we printed, unless we didn't know what to print )
Are we on the right track in determining whether a front+rear 4:10.1 axle ratios is feasible?
Old Nov 12, 2011 | 01:25 PM
  #30
Chump Change 10's Avatar
Chump Change 10
Smile
I would be looking for another dealer !! Your dealer sounds like he would put windsheild washer fluid in the radiator also !
