TPMS Valve Heads Up
Old Sep 13, 2012 | 09:02 PM
RAMULAK's Avatar
RAMULAK
So did they charge you for the new ones or did Dodge take care of it...?
Old Sep 13, 2012 | 09:47 PM
oldjeep's Avatar
oldjeep
I took it to the tire shop in town, so I paid out of pocket. I kind of doubt that there is a 73,000 mile warranty on valve stems Cost about $40 for the stem, kit, balance and remount.
Old Sep 14, 2012 | 02:50 PM
200amp's Avatar
200amp
had 2 of mine replaced by dealer about a month before my 3 year warr. was up. 2 had broken nuts , wouldnt change the other 1s out !!
Old Sep 15, 2012 | 12:15 PM
RAMULAK's Avatar
RAMULAK
I started my own thread about mine, just so people would go check theirs.
Found both my front tires stems cracked while I was doing my brakes today. When I called the dealer they said $80.00 a piece. I have 7/70 and they said they were covered but I have a $100.00 deductible so it really doesn't help that much.
Old Sep 15, 2012 | 08:40 PM
jacoblong44's Avatar
jacoblong44
if you have the sensors rebuilt every time you change the tires you will never have this issue. the rebuild kit is 10 bucks a piece... DO NOT GET A WHOLE NEW SENSOR...you dont need that part. the kit includes a rubber gasket, a new retaining nut which should be torqued to specs, and a valve core. if you ever have this problem take it to discount tire, tell them you have a flat ( which they do for free) and the tpms rebuild kit is included with the free service.
Old Sep 15, 2012 | 08:50 PM
oldjeep's Avatar
oldjeep
The rebuild kit only replaces the nut and seals, not the stem and mine did get a new kit at around 45K when I got the tires. The problem on mine was caused by the stem corroding inside the nut.
Old Sep 15, 2012 | 08:51 PM
oldjeep's Avatar
oldjeep
You don't need to replace the whole tpms. Any tire store will have the kit and stem. parts cost is around $15 from the tire store or $8 at the local auto parts store
Stem:
http://www.oreillyauto.com/site/c/de...5431&ppt=C0033
Kit:
Old Sep 16, 2012 | 08:30 AM
RAMULAK's Avatar
RAMULAK
Yeah that is what I thought. I think they are trying to bilk me for the whole TPMS unit.....Damned dealers.
Old Apr 24, 2013 | 07:12 PM
The Moose's Avatar
The Moose
Bringing this thread back up, I just discovered the same problem on my 2009. Never chnaged the tires. Don't know if the dealer will cover yet.
If you have had a failure (flat or cracked), go to NHTSA and file a complaint. This is very dangerous and a manufacturing defect that should be repaired for free. Especially important if you had a failure while on the road!
https://www-odi.nhtsa.dot.gov/Vehicl...nt/index.xhtml
Old Dec 3, 2013 | 11:16 PM
200amp's Avatar
200amp
200 miles from home and 1 of the original 2 piece valve stems let loose @ 70 miles an hour and cost me a 300.00+ tire , because the dealer wouldn't change all 4 valve stems at once. THANKS DODGE!!!
