Air Conditioning not working 2010 ram
Old Jul 8, 2012 | 09:58 PM
ilpoc88's Avatar
ilpoc88
Default Air Conditioning not working 2010 ram
hi there,
I have a 2010 dodge ram 1500 at the beginning of this summer I turned on my air conditioning and it would only blow warm air. Ive figured out that my compressor isn't engaging. Ive checked the fuse compartment and checked all of the hvac fuses. the owners manual diagram and the diagram under the hood have two different placement of fuses. according to the owners manual I have fuse (IOD-HVAC, U/Hood Lamp) that ins't getting power. I've checked for power at the A/C switch with a light tester and only got a very dull light. I've also unplugged the harness at the clutch and checked for power and there is nothing. thanks in advance for any help
Old Jul 9, 2012 | 12:05 AM
Cmerritt84's Avatar
Cmerritt84
Go to dealership if under warranty still.
Old Jul 9, 2012 | 11:13 AM
ilpoc88's Avatar
ilpoc88
I have a 110000km no warrenty
Old Jul 9, 2012 | 11:25 AM
BULLRAM's Avatar
BULLRAM
before you check out any thing else you need to have the freon checked for pressure, if there is none you have a leak, if there is enough then you go looking for electrical
Old Jul 10, 2012 | 09:29 AM
ilpoc88's Avatar
ilpoc88
If it is low on freon would that make the AC unit not turn on? Because i assume even with low feelin the unit should still engage? Am I wrong
Old Jul 10, 2012 | 09:33 AM
krp2012's Avatar
krp2012
No. With low freon the a/c clutch will not engage. Hence no power there. The blower will still blow air, but it wont kick the clutch on to prevent damage to it. Have the freon checked.
Old Jul 10, 2012 | 11:08 AM
hounddogg's Avatar
hounddogg
Low freon compressor will not engage. Its to keep from tearing it up. Low PSI switch.
Old Jul 11, 2012 | 06:37 AM
ilpoc88's Avatar
ilpoc88
Ok thanks guys
Old Jul 18, 2012 | 08:25 PM
lowriderman1225's Avatar
lowriderman1225
subscribed, would like to know what you find out.
Old Jul 18, 2012 | 09:17 PM
HEMI_ROM's Avatar
HEMI_ROM
My 09 has had the exact same issue, warm air out 3 times now. First 2 times for defective HVAC control heads (yes 2 ), just recently for a defective evaporator whatever that is. All under 09 warranty thankfully. My guess is you will go the same route with the HVAC control unit....NOT cheap...... Let us know, good luck.
