Old Aug 17, 2015, 01:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Fuel System Guides
Print Wikipost
2009 Ram 1500 5.7L - Poor gas mileage all of a sudden!
Old Dec 21, 2012 | 08:34 AM
  #21
hounddogg's Avatar
hounddogg
So far the ones that have posted using a program report decrease in fuel mpg. Evn onthe MPG settings. Your better off using that money for something more meaningful. Diesels benefit greatly and get get good gains from downloads.Gas engines do not.
Old Dec 21, 2012 | 10:34 AM
  #22
allmyTdrunken1's Avatar
allmyTdrunken1
Thanks hounddogg! I appreciate it. It's hard to figure out what works well and what doesn't. A lot if info in these forums. Mixed reviews. I just want to make my hemi the best it can be on a budget. Perhaps it's fine the way it is Performance wise. My magnaflow muffler cost just over $100 gave me the bark I wanted, yet it's still a quiet loud jusr enough without breaking out $700 for a cat back. And CAI. There's so many. Same thing mixed reviews again. But u figure I have only owned my truck less than a month. I got until next may when camping season starts to figure it all out
Old Dec 26, 2012 | 02:49 PM
  #23
awful knawful's Avatar
awful knawful
Originally Posted by allmyTdrunken1
I'm looking at a super chip 3865 flash paq. $200 used. Guy is going to program my truck right then n there to ensure its unlocked and works. Is this a good deal? Looking to gain some mpg for dd & power when I tow
i put the SC tuner in my 09CC Hemi. On the 87 tune I gained 2mpg in rural/city driving.
Old Jan 16, 2019 | 09:11 PM
  #24
Tony Rudolph's Avatar
Tony Rudolph
Originally Posted by NateDoggMag
Hi Everyone,
Maybe you can help a brother out. I typically keep an eye on the MPG indicator and noticed this past week that my typical 16+ average MPG is struggling to stay above 12 MPG. I have reset the MPG indicator at various times, seeing it creep up into the neighborhood of 15 MPG, but it's back in the tubes by the time I finish my 16 mile flat land commute from work.
I have read on the Gen 2 forums that the MAP sensor is known to fail, resulting in poor mileage, but have not found anything on the Gen 4 forum pertaining to poor mileage.
Anyone have any suggestions?
i have a 2009 with a 5.7 i was getting a lean code on bank 1 (p0171) my scanner says possible map sensor is having problems so i ordered a new one on ebay and no more check engine light but now my mpgs are like 12 or 13 they used to be 15-17 with old map sensor anybody know whats up with this?? I just got the truck and do love it but driving easy around town with a small trailer 2000 pounds total im getting 11.5-12.5 and im a granny driver i feel like this isnt right my last truck (chevy 4.8) was wayyyy better with same load etc should this ram be that bad on fuel? Im running 40psi in tires and air filter looks fine thanks guys for your time!
Old Jan 16, 2019 | 09:51 PM
  #25
Tony Rudolph
also i think that code might still be on the scanner ill have to double check that
Old Jan 17, 2019 | 10:58 AM
  #26
You should check the dates on threads before posting in them. In case you haven't noticed, this thread dates back to 2012. I would like to think he got it fixed by now.........
Old Jan 30, 2019 | 01:47 PM
  #27
Tony Rudolph
its me that is looking for info im still looking for some haha
Old Jan 30, 2019 | 03:27 PM
  #28
If your gas mileage took a dump after changing the map sensor..... that's where I would be tempted to start. Not all aftermarket parts are created equal..... If you got the duralast, or something equally as 'low quality', wouldn't surprise me if that wasn't at least part of the problem. (that you have now.....) I would be more tempted to have a look at what the O2 sensors are doing...... They don't last forever.
Old Jan 30, 2019 | 09:07 PM
  #29
Tony Rudolph
thank you buddy good tips !! so heres the update on my 2009 ram 1500 5.7 hemi i noticed 2 exhaust manifold bolts where broke on each side so i took the manifolds off we welded a nut on the broke off ones they where broke off in the block total pain the butt job to do took many hours put all new bolts new manifold gaskets glad that part is fixed. before i did this job i put the old map sensor back in and my mileage got better again but even after this job im still throwing a p0171 lean bank 1 code so i put a new bosch o2 sensor in bank one and no check engine light for about 60 or 70 miles now its back on same code the shop did a quick check for vaccuum leaks i cleaned throttle body with no leaks in exhaust its running better than ever but i gotta deal with check engine light maybe ill try sticking that aftermarket map back in and see if my mileage is still good and no check engine light whats your guys thoughts? I think the one in the truck is aftermarket too not sure. I just matched up the part number of the current one and ordered on Ebay maybe i should try to buy a high quality map now? I dont know what else to try any help would be great thanks in advance.
Old Jan 31, 2019 | 02:52 AM
  #30
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Wow my 2001 Ram 2500 Gasser gets 16/18 on 40in tires. Almost makes me not want to swap a Hemi in it
