Old Aug 17, 2015, 12:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problem Guides
Print Wikipost
Ticking sound when coasting?
Old Jul 11, 2016 | 10:48 PM
  #211
gerard143's Avatar
gerard143
yup that's the mds noise.
Old Jul 20, 2016 | 06:22 AM
  #212
11ram's Avatar
11ram
So got the truck back from the dealer yesterday. They fixed it but dnot know which of the 2 things fixed it. They noticed I had a cheap filter and don't know what kind of oil I had in it. So they use wynns engine flush and then did a fresh oil change. Also theres a bulletin out for the mds system for a drone or vibration noise which mine did not really sound like. But going around 40 or 50 km/h I do not hear the noise on the buildings. I'll keep everyone posted after a while to see if it comes back.
Old Jul 20, 2016 | 10:04 AM
  #213
Dusty48's Avatar
Dusty48
Do you know what the two things they replaced where?
Bests,
Dusty
Old Jul 20, 2016 | 10:43 AM
  #214
11ram's Avatar
11ram
They didn't replace anything. They were not sure out of the 2 things they did which was oil flush and then the mds bulletin which one actually cured it. I'm going with the sofare update for the mds system must have cured it.
Old Jul 21, 2016 | 07:04 AM
  #215
Dusty48's Avatar
Dusty48
Okay, well that is most interesting. Please keep us informed.
Regards,
Dusty
2014 Ram Big Horn 1500 Quad Cab2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at:042173 miles.
Old Aug 22, 2016 | 03:57 PM
  #216
ram10's Avatar
ram10
Just throwing it out there..but my 2010 had problems with cracked exhaust manifold bolts, which would cause an exhaust (ticking) noise. It wouldn't make the noise all the time just periodically. Hope this helps.....
Old Aug 22, 2016 | 04:16 PM
  #217
11ram's Avatar
11ram
Update. Since they did the mds bulletin and oil flush it was happening not as often. I was able to go to the dealer and repeat the noise for them on the hoist as I did at the Ford dealership I work for. So dodge is saying collaspable.lifters now. So in the next week they should have them replaced and hopefully the noise is gone. To me sounds like the cam phaser or timing chain rattling like the ford 5.4l do. Time will tell I'll keep updating when I know more.
Old Sep 8, 2016 | 10:57 AM
  #218
etprime's Avatar
etprime
Default Vids
Ive got a 2010 with 74K miles, mines doing it to. Here's an up close GoPro video placed on some refrigeration lines, sounds like a little jackhammer in there. I just purchased the truck used with a 30 day warranty, wondering what the little used car dealer shop mechanics will have to say about this. They already plan on reimbursing me for a pinion seal leak, but i feel like this might scare them
Old Sep 8, 2016 | 11:43 AM
  #219
11ram's Avatar
11ram
Update. Got my truck back from dodge and they replaced the mds lifters and noise is officially gone. They changed all 8 lifters. Lock pins in the lifters were turned inside of there selfs apparently. The job cost about 3500 but I had a aftermarket warranty which covered the repair for a dectucable of 150.
Old Sep 8, 2016 | 02:07 PM
  #220
etprime's Avatar
etprime
So after reading all 22 pages - sounds like a number of things has solved this?
Timing Chain/Guide/Tensioner
Cam Phaser
Lifters
PCM flash
yikes
