Old Aug 14, 2015, 05:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
ball joint replacement
Old Jan 14, 2014 | 05:32 PM
rkfguard's Avatar
rkfguard
Default ball joint replacement
I have an 09 dodge ram crew and the lower driverside ball joint needs replacing...has anyone done this yet..if so..can I just replace the ball joint instead of the whole control arm...
Old Jan 14, 2014 | 06:00 PM
HEMI_ROM's Avatar
HEMI_ROM
Sorry I can't answer your question, but can you tell me how miles are on your 09? Thanks.
Old Jan 14, 2014 | 07:39 PM
Huntjunkie41's Avatar
Huntjunkie41
You will need a ball joint press kit. You can do just the ball joint if its the lower. I'm not sure about the upper. Upper its usually a whole arm swap.
Old Jan 15, 2014 | 10:45 AM
rkfguard's Avatar
rkfguard
Default ball joint
do you know what the part number would be for the lower ball joint...I have 48,000 miles on it...the pass side is tight..the drivers side has at least 1/8 inch up and down play..thanks
Old Jan 15, 2014 | 08:04 PM
Huntjunkie41
When I talked to the dealer a while ago they did not list aftermarket ball joints for the 09s and up yet. The Tech told me the part number for the lower control arm was the same as the 2002 through 2008 so the ball joint would be the same as well.
I will only buy Moog.
Moog K7465 for the Lower 2WD
Moog K7467 for the Lower 4WD Crew Cab
These are the part number also listed on amazon for 2009 now.
Old Jan 15, 2014 | 08:24 PM
rkfguard's Avatar
rkfguard
that's what ive found out too..they have the control arms for 06 and up to 2012,,,but not the ball joints only go up to 08...have you done your lowers yet...I guess I can buy one at autozone and see if it matches up to mine..then I will post my findings..its just another way to have people buy oem..thanks
Old Jan 16, 2014 | 02:28 PM
KDubya's Avatar
KDubya
Rkfguard -
I also have an '09 Crew an fit is in the shop now for the driver's side lower ball joint - my guy says i'd need to do the whole control arm because you can't get just the ball joint. The OEM price was $600+ and the aftermarket about half that for the control arm.
It seems that the lower ball joint has gone dry - and there's no way to grease it.
Haven't decided yet what if anything i'll do.
KDubya
Old Jan 16, 2014 | 05:36 PM
Pedro Dog's Avatar
Pedro Dog
https://www.dodgeparts.com/oe_parts_...8c172293f3a194
Old Jan 16, 2014 | 08:09 PM
stlram's Avatar
stlram
Are you sure you need a new ball joint or are you talking about a tie rod end? I know these truck are notorious for tearing up tie rods but never heard of ball joints yet. Just asking because I have an 09 with 92000 on it and I havent touched the front end other than to change shocks.
Old Jan 17, 2014 | 01:14 AM
rkfguard's Avatar
rkfguard
yes its the ball joint...the tie rods are tight...
