Tailgate drops backup camera quits
Old Mar 30, 2016 | 12:58 PM
706jim's Avatar
706jim
Default Tailgate drops backup camera quits
Like the title says.
I'm guessing that there is a loose connector or the camera is somehow damaged.
What is the procedure to remove the tailgate latch/lock assembly to either check the connection or replace the camera?
I don't think the problem involves the display unit as the problem started immediately after the partially closed tailgate dropped.
Old Mar 30, 2016 | 03:28 PM
bluebeast1562's Avatar
bluebeast1562
Yeap, sounds like a loose connection, check the connection on the bottom of the tailgate when it is open. Then while the tailgate is down, there are a number of hex head screws that allow access to the inner workings of the tailgate.
I would also suggest the DZ tailgate assist, helps with not allowing the tailgate to slam down and easy to install.
Good luck.
Old Mar 30, 2016 | 10:00 PM
706jim's Avatar
706jim
Broken ground wire exiting harness just before connector for camera.
A relatively easy repair once I realized that there was a removable access panel on the tailgate (mine is embalmed in bed spray liner so never noticed it before).
Cost to "analyze problem" at local dealership $156/hour!
Thanks to Bluebeast for the suggestions.
