will crank but wont start. rwplaced creank and cam sensor
Old Jul 26, 2018 | 09:07 PM
Daren's Avatar
Daren
Default will crank but wont start. rwplaced creank and cam sensor
my 2014 ram 1500 will crank wont start replaced crank and cam sensor still no start
Old Jul 27, 2018 | 07:26 AM
Moving to fourth gen ram section.
Old Jul 27, 2018 | 07:46 AM
SHO Rod's Avatar
SHO Rod
Have you checked for spark and fuel pressure?
-Rod
Old Jul 30, 2018 | 01:43 PM
Robert Jones 1968's Avatar
Robert Jones 1968
i second that .. fuel pump relay dies check for power to the fuel pump while cranking
it should be blue (with an orange trace) wire in the 40-way electrical connector under the tipm .
see this document
https://drive.google.com/file/d/1slf...ew?usp=sharing
Old Jul 31, 2018 | 01:01 AM
daktwos's Avatar
daktwos
Try removing the snorkel to the throttle body and shoot a small squirt of starting fluid into throttle body and replace snorkel.No need to tighten,just put back on to prevent backfire.Crank engine over and see if it runs for a few seconds then stalls out.If yes,it's a fuel supply issue,likely bad pump,relay,regulator etc.
