Rough ride
Old Oct 31, 2018 | 11:52 AM
Grayswb14's Avatar
Grayswb14
Default Rough ride
Recently purchased 2014 ram 1500 swb, love the truck but it rides like a wagon, I understand the previous owner lowered front with shorter springs, every little bump & hole is bone jarring even after replacing oem shocks with bilstein 4600s, will the shorter springs effect ride quality that much? Please advise.
Old Oct 31, 2018 | 11:56 AM
Yes. Put OEM springs back on it.
Old Oct 31, 2018 | 12:00 PM
rich6111's Avatar
rich6111
Yes,it will ride stiffer and give rougher ride with every bump.
Old Oct 31, 2018 | 01:32 PM
SHO Rod's Avatar
SHO Rod
If the PO replaced the springs with shorter springs, the replacement springs probably have a higher spring rate than OEM to reduce the chances of bottoming out, hence the stiffer ride.
-Rod
Old Nov 4, 2018 | 11:59 PM
Grayswb14's Avatar
Grayswb14
Thanks for info. First dodge truck & new to forum, just looking for some answers.
Old Nov 5, 2018 | 12:13 AM
Grayswb14's Avatar
Grayswb14
Had hoped & thought for sure the new bilstein shocks would smooth out rough ride after reading reviews on how great they are, have bilsteins for rear also but haven't installed them yet, guess i need to face the fact that its a truck & its gonna ride like one & not a caddy. Would any after market spring designed for lift be ok or would oem be better?
Old Nov 5, 2018 | 07:29 AM
If you want an OEM ride, use OEM springs. It’s a truck through. Will never ride like a caddy.
Old Nov 5, 2018 | 07:41 AM
SHO Rod's Avatar
SHO Rod
On a positive note though, because of the suspension and spring setup on the Ram, it's been considered to have a smoother ride than the other full-size pickup trucks per the automotive press. So the OEM ride of a Ram is probably as close to a Caddy as you're going to get in a full-size truck.
-Rod
Old Nov 5, 2018 | 09:16 AM
Throw some weight in the bed, and it will ride better. Of course, fuel mileage suffers......
Old Nov 6, 2018 | 10:23 PM
Grayswb14's Avatar
Grayswb14
Installed bilsteins on rear today, noticeably better ride, now if I can just get the front squared away I'll be happy, until I want to change something else.
