2009 ram 5.7l hemi cylinder 5 misfire
Old Aug 30, 2019 | 06:45 PM
Clayton Hoyt's Avatar
Clayton Hoyt
Default 2009 ram 5.7l hemi cylinder 5 misfire
Hello everyone, looking for some help on my hemi has a single cylinder #5 misfire here is what I have done so far...
Changed plugs on #5
Swapped #3 coil to #5
Swapped #3fuel injector to #5
Pulled valve cover look at #5 intake valve but seems to be moving up and down like any others have not look at the exhaust valve on that cylinder yet..
The truck misfired at idle and loss of power.
And yes I have check for power at coil and injector
Thanks
Old Aug 30, 2019 | 06:52 PM
Compression test.
Old Aug 30, 2019 | 07:27 PM
Clayton Hoyt
Changed plugs on #5
Thanks
I will try and do that tomorrow need to find one to borrow thanks for your quick reponse
Old Aug 31, 2019 | 08:31 AM
TrueDogman's Avatar
TrueDogman
Do you have any valve train noise ?
Old Aug 31, 2019 | 08:46 AM
Clayton Hoyt
Yes i do she has a little tick sounds like in the center on top of the engine
Old Aug 31, 2019 | 09:40 AM
TrueDogman's Avatar
TrueDogman
Continue with your compression check as HeyYou said and let us know.
If your tick is louder than the normal hemi tick 😁 investigate that further. Research camshaft and lifter failure...sorry to say. Some good posts here.
Old Sep 3, 2019 | 04:33 PM
Mike Sal's Avatar
Mike Sal
My 2009 had 92k on it when it suffered the same symptoms & resulted in bad cam / lifter. Did the work myself for about 800 bucks.....pretty aggravating......
Mike S
Old Sep 6, 2019 | 04:12 PM
donald mcdougall's Avatar
donald mcdougall
Default bad lifters
i had the same problem. turns out its sticking lifters wearing out cam lobes.talked to dodge who admitted the lifters were faulty in the 5.7,6.2,and 6.4 and have now been changed in newer models.i think it should have been a recall since so many hemis have this problem
Old Sep 6, 2019 | 06:43 PM
Any idea what model year they went to the 'new' design?
