Intermittent missing when starting
Old Sep 19, 2019 | 12:04 PM
cruch9's Avatar
cruch9
Default Intermittent missing when starting
I have a 2011 Ram Sport 5.7 with around 90k. About once a month when I start the engine it will start but has a severe missing. It will always go away if I either shut off the engine and restart or push on accelerator. It has me puzzles what could be causing it. I have replaced plugs but not coil packs. Runs great other than this issue. I wondering if I just let off the ignition key to soon?? Any ideas? Thanks.
Old Sep 19, 2019 | 09:27 PM
TrueDogman's Avatar
TrueDogman
Any check engine light? Any error codes? I would be thinking a sticky fuel injector possibly?? Ignition key and letting off to soon will not be suspect
Old Sep 20, 2019 | 07:38 AM
cruch9's Avatar
cruch9
Nothing, no error codes, no check engine light. nothing. it is weird.
Old Sep 20, 2019 | 09:07 AM
rsdata's Avatar
rsdata
I would try to start it in the dark and look for sparks by the ignition wires, from either breaks in the wire itself or maybe moisture on the wires.
Old Sep 20, 2019 | 03:15 PM
cruch9's Avatar
cruch9
Even though it runs completely fine other than the random starting issue I mentioned? Thanks
Old Sep 23, 2019 | 06:25 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the HEMI is Coil on Plug, there are no traditional spark plug wires to check for arcing/sparks from. . . . and the 12v(max) signal/supply wires in the harness wouldnt be sparking unless they were touching, which would be a more consistent problem
Old Sep 26, 2019 | 07:53 AM
cruch9's Avatar
cruch9
any ideas? Letting off the ignition key to soon wouldnt cause this? It only happens about once every couple months.
Old Sep 26, 2019 | 09:31 AM
How does the timing fit in with fueling up the truck?
