Light Issue Occuring
There will be an issue with a wheel speed sensor or other aspect of your stability control system. You should pull diagnostic codes for the system and diagnose rather than just attempting to clear the code or codes.
-Rod
-Rod
Okay, I will pull the codes today and post them.
Just be aware that not all diagnostic tools can access the stability control system or even the ABS systems on these vehicles. So unless you know yours can, don't be too surprised if it comes back with either no codes or only powertrain diagnostic codes.
-Rod
-Rod
Mode $06 report generated by Torque for Android
Vehicle VIN: 1C6RR7KTXFS618749
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: 68232414AH
H
Test report:
MID:$01 TID:$91
- O2 Bank 1 Sensor 1
Max: 655.34998% Min: 217.5%
Test result value: 319.82001%
PASS
MID:$01 TID:$92
Max: 1.99882 Min: 0.11273
Test result value: 0.34395
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.49V Min: 0V
Test result value: 0.49V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 65.535V Min: 0.666V
Test result value: 0.784V
PASS
MID:$02 TID:$81
Max: 65.535 Min: 0.36
Test result value: 5.114
PASS
MID:$02 TID:$82
Max: 240 Min: 0
Test result value: 38
PASS
MID:$02 TID:$83
Max: 0.2745V Min: 0V
Test result value: 0.21557V
PASS
MID:$05 TID:$91
- O2 Bank 2 Sensor 1
Test result value: 311.26999%
PASS
MID:$05 TID:$92
Max: 1.99882 Min: 0.1048
Test result value: 0.22466
PASS
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Max: 0.49V Min: 0V
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Test result value: 0.803V
PASS
MID:$06 TID:$81
Test result value: 3.19
PASS
MID:$06 TID:$82
Max: 240 Min: 0
Test result value: 58
PASS
MID:$06 TID:$83
Test result value: 0.25486V
PASS
MID:$21 TID:$92
- Catalyst Monitor Bank 1
Max: 0.64% Min: 0%
Test result value: 0%
PASS
MID:$22 TID:$92
- Catalyst Monitor Bank 2
Max: 0.64% Min: 0%
PASS
MID:$35 TID:$82
- VVT Monitor Bank 1
Max: 6° Min: 0°
Test result value: 0.5°
PASS
MID:$35 TID:$84
Test incomplete or dependant test failed
MID:$39 TID:$87
- EVAP Monitor (cap off)
MID:$3a TID:$87
- EVAP Monitor (0.090")
Max: 655,350ms Min: 0ms
Test result value: 0ms
PASS
MID:$3c TID:$85
- EVAP Monitor (0.020")
MID:$3c TID:$86
MID:$3c TID:$90
Max: 4,300minute Min: 12minute
Test result value: 450minute
PASS
MID:$3d TID:$89
- Purge Flow Monitor
PASS
MID:$3d TID:$90
MID:$3d TID:$91
MID:$3d TID:$92
MID:$3d TID:$93
MID:$3d TID:$94
Max: 32,767 Min: 200
Test result value: 1,936
PASS
MID:$41 TID:$97
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 165°C Min: 0°C
Test result value: 35°C
PASS
MID:$42 TID:$97
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 190°C Min: 0°C
Test result value: 70°C
PASS
MID:$45 TID:$97
- O2 Heater Monitor Bank 2 - Sensor 1
Max: 165°C Min: 0°C
Test result value: 25°C
PASS
MID:$46 TID:$97
- O2 Heater Monitor Bank 2 - Sensor 2
Max: 190°C Min: 0°C
Test result value: 55°C
PASS
MID:$81 TID:$90
- Fuel System Monitor Bank 1
Max: 1.10935 Min: 0
Test result value: 1.03056
PASS
MID:$81 TID:$91
Max: 1.99882 Min: 0.8895
Test result value: 0.95319
PASS
MID:$81 TID:$92
MID:$82 TID:$90
- Fuel System Monitor Bank 2
Max: 1.10935 Min: 0
Test result value: 1.01473
PASS
MID:$82 TID:$91
Test result value: 0.97713
PASS
MID:$82 TID:$92
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
PASS
End of report.
H
Test report:
MID:$01 TID:$91
PASS
MID:$01 TID:$92
PASS
MID:$02 TID:$07
Max: 0.49V Min: 0V
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
PASS
MID:$02 TID:$82
Max: 240 Min: 0
PASS
MID:$02 TID:$83
PASS
MID:$05 TID:$91
PASS
MID:$05 TID:$92
PASS
MID:$06 TID:$07
Max: 0.49V Min: 0V
PASS
MID:$06 TID:$08
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
Max: 240 Min: 0
PASS
MID:$06 TID:$83
PASS
MID:$21 TID:$92
Max: 0.64% Min: 0%
PASS
MID:$22 TID:$92
Max: 0.64% Min: 0%
PASS
MID:$35 TID:$82
Max: 6° Min: 0°
PASS
MID:$35 TID:$84
MID:$39 TID:$87
MID:$3a TID:$87
PASS
MID:$3c TID:$85
MID:$3c TID:$86
MID:$3c TID:$90
PASS
MID:$3d TID:$89
PASS
MID:$3d TID:$90
MID:$3d TID:$91
MID:$3d TID:$92
MID:$3d TID:$93
MID:$3d TID:$94
PASS
MID:$41 TID:$97
Max: 165°C Min: 0°C
PASS
MID:$42 TID:$97
Max: 190°C Min: 0°C
PASS
MID:$45 TID:$97
Max: 165°C Min: 0°C
PASS
MID:$46 TID:$97
Max: 190°C Min: 0°C
PASS
MID:$81 TID:$90
Max: 1.10935 Min: 0
PASS
MID:$81 TID:$91
PASS
MID:$81 TID:$92
MID:$82 TID:$90
Max: 1.10935 Min: 0
PASS
MID:$82 TID:$91
PASS
MID:$82 TID:$92
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0b
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0b
PASS
MID:$a7 TID:$0c
PASS
MID:$a8 TID:$0b
PASS
MID:$a8 TID:$0c
PASS
MID:$a9 TID:$0b
PASS
MID:$a9 TID:$0c
PASS
End of report.
Trending Topics
Torque is an amazing app for free, but it is limited in what systems it can access. Since you're using Torque that tells me two things - you have an Android phone/tablet and you have a means of connecting that phone/tablet to the vehicle. For less than the cost then to either go to a shop to get the ABS/Stability code read, or to buy a dedicated scan tool that can, you can purchase AlfaOBD for Android and gain full access to your Ram's systems. I don't have any ties to AlfaOBD other than being a satisfied customer. I have an Autel MS906BT scan tool that cost a WHOLE lot more than AlfaOBD, but there are features for my Ram and Charger that my Autel can't do but AlfaOBD does. I don't think your 2015 Ram will have the Security Gateway Module, I think that was implemented later, but you may also want to check into that before purchasing AlfaOBD if you decide to go that route.
-Rod
-Rod
