4wd problem
Old Aug 10, 2024 | 12:58 PM
Grainman1965's Avatar
Grainman1965
Question 4wd problem
anyone know or have issues like i'm having? got a 2011 Ram 1500 5.7 and the 4wd auto comes on then 4wd light comes on then same time 4wd low flashes. I changed the front diff. 4wd. actuator but that has done nothing. after doing that 4wd light stays on steady with 4wd low coming on also blinking but selector switch is in 2wd. anyone can tell me what could possibly be? thanks for any info!
Old Aug 11, 2024 | 08:46 AM
dodgetruck2's Avatar
dodgetruck2
I'm not fully understanding what's happening, the light is cycling through the 4wd modes at random, or they're all on at the same time? By 4wd actuator, you mean the motor on the side of the transfer case?
Old Aug 11, 2024 | 09:31 AM
Grainman1965
yes while driving truck in 2wd the 4wd auto light comes on then it will change to 4x4 light with 4x4 low light flashing. i never even touch the selector switch. i changed the front diff actuator but that didn't do a thing.
Old Aug 11, 2024 | 11:11 AM
Bad switch, or bad transfer case control module would be my guess.
Old Aug 11, 2024 | 01:24 PM
dodgetruck2
The actuator on the transfer case would be my suspect. I've not fully invested time on how the auto function works, but could have an issue with the encoder circuit on the transfer case actuator not detecting shaft position correctly
Old Aug 11, 2024 | 01:28 PM
One of the reasons I like having that stick on the floor to tug on when I need 4x4.
Old Sep 5, 2025 | 06:52 AM
Dakota Bloke's Avatar
Dakota Bloke
This sounds similar to the issue I have, first I noticed the 4x4 dash light flickering, a month or 2 later, it would indicate both 4x4lo. A short while after, had the truck spontaneously going into 4WD without touching the switch. Quite possibly in my case the electric shift transfer case motor playing up, or the TC module. I know it isn't the switch as I have replaced that one.
Just a thought for you as it kinda sounds like mine. Although mine will try and select 4x4 when the truck isn't being used, very bazaar. Maybe my shift motor is shorting out inside. Man I hate electrics!
