Need help please
Old Dec 20, 2024 | 05:32 PM
Prokeyz's Avatar
Prokeyz
Default Need help please
I’m a locksmith in Michigan I have a 2013 dodge ram 1500 I was messing around with my XTool pro pad G2 turbo I missed something up,
or erased something now when I get in the truck starts up fine and I’ll put it in drive when I hit the gas nothing happen so if any one can help me please.thank you very much.
Old Dec 20, 2024 | 10:48 PM
SHO Rod's Avatar
SHO Rod
Please provide more detail on the scenario. What system or systems were you accessing with the XTool prior to discovering the issue? When you say "nothing happen" do you mean the engine does not increase in engine speed? If you depress the accelerator while in Park does the engine speed increase? Is the red lightning bolt appearing on the information center when you start the truck? Did you happen to go into the throttle calibration with the XTool, and maybe enter the throttle calibration without following through?
-Rod
Old Dec 21, 2024 | 08:45 AM
Prokeyz's Avatar
Prokeyz
I think I erased all memory when I get in the truck. The truck starts right up but when I put it in drive or in park and hit the accelerator The engine speed doesn’t increase and yes, I have the red lighting bolt On the dash and the XTool It’s not giving me an option to do a throttle calibration and thank you for your help.
Old Dec 21, 2024 | 01:20 PM
SHO Rod's Avatar
SHO Rod
The red lightning bolt indicator is indicating an issue with the electronic throttle. Have you used the XTool to scan for active diagnostic codes across the systems? I would expect the throttle to be part of the Powertrain system, but it could also show up in the Instrument Cluster or maybe even the Body Control Module.
-Rod
Old Dec 22, 2024 | 03:44 PM
Prokeyz's Avatar
Prokeyz
Hello sir I got the accelerator fixed and calibrated, but I still have some more issues. I have a lot of issues and codes I will attach pictures of all the codes if anybody can help thank you.
Old Dec 22, 2024 | 03:59 PM
I would be real tempted to reset the computer, and start fresh....... WAY too much going on there.
Old Dec 22, 2024 | 04:07 PM
Prokeyz's Avatar
Prokeyz
Hello there how do I reset the computer Can you help please
Old Dec 22, 2024 | 09:14 PM
Your scanner should be able to do it, otherwise, disconnect the battery open a door, leave it sit for five minutes or so, close the door.... hook the battery back up, and if your truck actually uses a key, turn the truck to 'on', not start, count to ten, then start the truck. That gives the PCM a chance to learn the zero values for various sensors.
Old Dec 22, 2024 | 10:19 PM
Prokeyz's Avatar
Prokeyz
Merry Christmas everyone god bless thank you so much for the help 🙏.
Old Dec 23, 2024 | 09:40 AM
SHO Rod's Avatar
SHO Rod
I agree, you have a lot of codes showing up as stored versus active, so at a minimum clear the diagnostic codes and see what remains. Also, some of the codes shown could be related to low voltage, so make sure your battery is charged up and then clear the codes again.
-Rod
