No crank no start
Old Oct 19, 2025 | 06:25 PM
koytster's Avatar
koytster
Default No crank no start
Needing help with a no crank no start on a 2009 dodge ram 1500 after new cam and lifters. Key turns everything on and clicks in start position security red dot flashes when in run position
Old Oct 19, 2025 | 07:22 PM
Need to reset security. Might be a procedure for that in the owners manual.
Old Oct 19, 2025 | 08:03 PM
koytster's Avatar
koytster
could that be why it is also throwing codes for no communication with pcm
Old Oct 19, 2025 | 08:52 PM
That would explain why it doesn't wanna start......
Old Oct 19, 2025 | 09:28 PM
koytster's Avatar
koytster
Ig that’s true
Old Oct 20, 2025 | 01:55 PM
SHO Rod's Avatar
SHO Rod
Have you checked the fuses for any that are blown? Maybe through the process of reassembly a wire got pinched causing a fuse to blow and the PCM or a critical module/sensor to not get power and therefore you're getting a no start condition.
-Rod
Old Oct 20, 2025 | 03:32 PM
koytster's Avatar
koytster
-Rod
Yes checked all fuses and they are good.
Old Oct 20, 2025 | 06:24 PM
SHO Rod's Avatar
SHO Rod
Have you checked to see if you are getting voltage to the starter solenoid? Are there any other things that you have checked that were not mentioned above so we don't keep offering suggestions only to have you reply that you've already checked that or that it might be related to a code that you're also getting?
-Rod
Old Oct 20, 2025 | 06:50 PM
koytster's Avatar
koytster
-Rod
have checked all fuses and relays. Not getting power to exciter wire on starter. It has codes for no pcm communication and a can bus C code.
Old Oct 20, 2025 | 07:54 PM
Figure out the no communication first. I don't think that would be a product of the security system...... Just the other way around I should think.
