Old Aug 6, 2015, 11:49 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Horn..wipers..turn signals..high beams..NOTHING!
Old Feb 1, 2012 | 08:10 PM
Mikeyyy816's Avatar
Mikeyyy816
Default Horn..wipers..turn signals..high beams..NOTHING!
So I get in my truck this morning...and I have no wipers, horn, turn signals (but my hazards worked, odd), no high beams, no brake lights, no power inverter, can't turn traction control on or off, and no control over the EVIC (temp work, mte works, but I can't use any scroll functions), radio works fine, and all in cab lights work fine and headlight low beam and fogs work just fine.
I pulled all fuses in the fuse box above the TIPM and all looked good, no corrosion or any sights of water intrusion. I disconnected the batt for 45 mins to see if that'd help, still nothing. Truck is running just as it did before all these issues, so no issues on that end, just electrically I'm having issues. It's scheduled to go to the dealer tomorrow when I get out of work, does anyone think a computer "reflash" will solve this issue or did the TIPM prob. just crap itself?
I've read a few post's that the 4th gen TIPM's are known to go out...hoping this is not the issue here. Anyone w/ insight would be great! Thanks guys.
Old Feb 1, 2012 | 09:18 PM
Pedro Dog's Avatar
Pedro Dog
I just looked thru the TIPM connectors and functions looking for a common connector to your issues and they all use different connectors from the TIPM. I did not find where the EVIC has anything to do with the TIPM but on C7, the CAN buses are connected to the TIPM. I have worked with Flash memory and usually it doesn't just "corrupt itself" but I've seen it happen when reflashing fixed things. Probably the TIPM is on it's way out. I don't know if I can get the TIPM connectors on here but I'll try. First one is C7, second C4 and C3. Well, the pictures did not paste properly- sorry.
MODULE-TOTALLY INTEGRATED POWER - (ENGINE) 50 WAY
CAVITY
CIRCUIT
FUNCTION
1 - - 2 - - 3 - - 4 - - 5 F941 20PK IGNITION RUN/START CONTROL OUTPUT 6 - - 7 - - 8 N4 20DB/WT FUEL LEVEL SENSOR SIGNAL 9 - - 10 W7 20BR/GY WIPER PARK SWITCH SENSE 11 - - 12 L91 22WT/BR HAZARD SWITCH SENSE 13 L51 18WT BRAKE LAMP SWITCH OUTPUT 14 G75 22VT DRIVER DOOR AJAR SWITCH SENSE 15 G74 22VT/WT PASSENGER DOOR AJAR SWITCH SENSE 16 G77 22VT/GY LEFT REAR DOOR AJAR SWITCH SENSE 17 G76 22VT/YL RIGHT REAR DOOR AJAR SWITCH SENSE 18 - - 19 - - 20 - - 21 - - 22 - - 23 - - 24 D72 22WT/DG DIAGNOSTIC CAN C (+) 25 D71 22WT/DB DIAGNOSTIC CAN C (-) 26 D265 22WT/GY CAN IHS BUS (125K) (+) 27 D264 22WT/OR CAN IHS BUS (125K) (-) 28 D52 22WT/LG CAN C BUS (+) 29 D51 22WT/LB CAN C BUS (-) 30 F20 20PK/WT IGNITION RUN/START CONTROL OUTPUT 31 - - 32 - - 33 - - 34 - - 35 - - 36 P807 20LG/LB INVERTER SWITCH SIGNAL 37 - - 38 - - 39 - - 40 - - 41 - - 42 - - 43 - - 44 A128 20RD/OR ADJUSTABLE PEDALS MOTOR DRIVER 45 - - 46 G109 20LG/TN FUEL LEVEL SENSE RETURN 47 L62 18WT/YL RIGHT REAR TURN LAMP DRIVER 48 L217 16WT/VT PARK LAMP FEED 49 L63 18WT/DG LEFT REAR TURN LAMP DRIVER 50 L17 16WT/LG PARK LAMP FEED this one is C4
MODULE-TOTALLY INTEGRATED POWER - (FRONT END MODULE) 16 WAY
CAVITY
CIRCUIT
FUNCTION
1 L911 18BK/LB LEFT HEADLAMP RETURN SIGNAL 2 L33 18WT/LG LEFT HIGH BEAM DRIVER 3 G70 20VT/LB HOOD AJAR SWITCH SENSE 4 L161 16WT/LG LEFT FRONT TURN SIGNAL CONTROL 5 L160 16WT/TN RIGHT FRONT TURN SIGNAL CONTROL 6 - - 7 L34 18WT/GY RIGHT HIGH BEAM DRIVER 8 L910 18BK/LG RIGHT HEADLAMP RETURN SIGNAL 9 L43 18WT/DB LEFT LOW BEAM DRIVER 10 W1 20BR/TN WASHER FLUID LEVEL SWITCH SENSE 11 - - 12 L61 16WT/LG LEFT FRONT TURN LAMP DRIVER 13 L60 16WT/TN RIGHT FRONT TURN LAMP DRIVER 14 G31 20VT/LG AAT SIGNAL 15 G931 20VT/BR SENSOR GROUND 16 L44 18WT/TN RIGHT LOW BEAM DRIVER
and C3
MODULE-TOTALLY INTEGRATED POWER - (FRONT END MODULE) 26 WAY
CAVITY
CIRCUIT
FUNCTION
1 N24 10DG/DB HIGH SPEED RAD FAN CONTROL 2 - - 3 - - 4 - - 5 - - 6 - - 7 - - 8 N23 10DB/DG LOW SPEED RAD FAN CONTROL 9 - - 10 - - 11 - - 12 - - 13 - - 14 - - 15 - - 16 - - 17 - - 18 W20 18BR/YL REAR WASHER PUMP MOTOR CONTROL 19 W10 18BR FRONT WASHER PUMP MOTOR CONTROL 20 - - 21 X22 20GY/LB FUSED HORN CONTROL OUTPUT 22 - - 23 L89 18WT/YL (FOG LAMP) LEFT FRONT FOG LAMP CONTROL 24 L90 18WT/OR (FOG LAMP) RIGHT FRONT FOG LAMP CONTROL 25 X21 20GY/YL FUSED HORN CONTROL OUTPUT 26 - -
Locations
Old Feb 1, 2012 | 09:25 PM
Mikeyyy816's Avatar
Mikeyyy816
Pedro thanks! If it is the TIPM, it should still be covered under warranty, I'm hoping and I hope they can say it's the TIPM before anything else fails.
Old Feb 1, 2012 | 09:54 PM
thmupr's Avatar
thmupr
Try unhooking the battery for 10 minutes. My truck did something similar once, I had no gauges, radio wouldn't come on, no power windows, etc.. Had to reboot the data bus system. Everything worked fine after that! Might not help you but it's easy to try!
Old Feb 1, 2012 | 09:55 PM
Mikeyyy816's Avatar
Mikeyyy816
I unhooked the battery for 45 mins earlier today when I got home from work...no luck
Old Feb 1, 2012 | 10:07 PM
Dawizman's Avatar
Dawizman
I don't mean to freak you out or anything, but I seem to remember reading a horror story involving a 4th gen ram and a blown TIPM being blamed on HID's, and warranty being declined because of them. I'm not sure what the specifics were in that case, but I really hope they don't try to throw the same bs at you.
Old Feb 1, 2012 | 10:08 PM
thmupr's Avatar
thmupr
Damn.. Was worth a shot!
Old Feb 1, 2012 | 10:46 PM
Mikeyyy816's Avatar
Mikeyyy816
That'd be bad since I am running HID's...hoping they don't try and pull that against me. I'll keep y'all posted w/ what the dealer says. Who know's hopefully a Computer reflash solves this completely. But thanks for the insight!
Old Feb 2, 2012 | 07:11 AM
Shibby927's Avatar
Shibby927
I don't know if these new RAMs have an FCM (Forward Control Module) like my 2006 Dakota had but I had a somewhat similar issue when my FCM on my 06 Dakota crapped out. The FCM communicates with all of the various modules throughout the vehicle so when mine took a dump I pretty much could just drive and listen to the radio much like you. I can't find anything about an FCM being in our trucks but I'm guessing it's gotta be something equivalent to that.
Old Feb 2, 2012 | 07:35 AM
Cmerritt84's Avatar
Cmerritt84
Put your stock halogens back in before you to the warranty police.
