5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
4 Wheel Drive Actuator Oil Leak
Old Nov 21, 2024 | 11:13 AM
TomShearer's Avatar
TomShearer
Question 4 Wheel Drive Actuator Oil Leak
First post on the forum! But certainly not my first use of this awesome resource.
I had the common "Serve 4WD" light come on. After checking the connections to the actuator, I replaced it. No one should pay the dealer to do this work. It is at best a 20 minute job, 4 bolts. The hardest part is getting the electrical connection off, and the trick to not losing gear oil is to put the truck on a slant, driver's side down. MY ISSUE: I cannot get the new actuator to stop leaking gear oil. I've taken it back off three times to clean the surfaces, second time to put a gasket seal compound on the surfaces, third time to torque it a little more. Still dripping slightly from the mating surfaces. My next step is to make a gasket. The actuator has a very thin rubber gasket that stands up from the surface. I'm also questioning if I tightened the bolts too much for that type of gasket. Reaching out to see if someone has the answer.
Old Nov 21, 2024 | 11:49 AM
Are you sure it is coming from the gasket surface, and not leaking elsewhere on the actuator, and just ending up there???
Old Nov 21, 2024 | 11:57 AM
TomShearer's Avatar
TomShearer
Thanks.
I checked the actuator all over with a clean paper towel, and since I've had it off three times, looked carefully for cracks.
Old Nov 21, 2024 | 12:03 PM
Gotta be something else going on there then..... The sealer should have done the job.... No clue why it didn't.
Old Nov 21, 2024 | 12:13 PM
TomShearer's Avatar
TomShearer
Hoping someone might tell me the torque specs on the 4 bolts. I did search other forums and only found one answer that was 21 ft/lbs. I was looking for another that would validate that, and I did torque the bolts the first time to 21. Felt like it wasn't enough so I went to 30 the next time.
Old Nov 21, 2024 | 01:20 PM
Did you seal the bolt threads as well?
Old Nov 21, 2024 | 01:52 PM
TomShearer's Avatar
TomShearer
Well.....no
but i'll do it.
I can have that thing off in 5 minutes now. Think i'll still make a gasket pattern while it's off and the sealer as well.
Old Nov 21, 2024 | 01:55 PM
Originally Posted by TomShearer
Well.....no
but i'll do it.
Worth a shot.
Old Nov 24, 2024 | 12:20 PM
TomShearer's Avatar
TomShearer
An end to this saga. My last attempt to stop the oil leak from the actuator was to make a gasket and apply sealer to all surfaces. Thought for sure this would stop the drip. NOPE! So now I figure there must be a defect somewhere. I removed the rock shield and now saw that the oil was coming from a hairline crack in the plastic. Amazon is coming through again with a replacement on the way before having to return the original part. Truck works fine with the exception of a few drips of oil.
