All new speaker wires?
ORIGINAL: rtkota5point9
I'm telling you it WILL work.Done many. Something's wired wrong.Is there a Blue/white wire on the headunit? If so, it needs to be hooked to that one. Normally Blue= power antenna Blue/White= remote/amp turn-on. But if there is only a solid blue, then that's the right one.
That just doesnt make any sense. My boss had an 04 with Infinity, and I am certain we didn't bypass that. Maybe it was a hold over 03? I've done tons of rams at work, and I think it's funny that I've never run across this problem. Weird
Well that was a waste of time. The pink/black wire hookup didn't work either. I even moved the wire on the Metra harness to plug into the amp power wire on the factory harness and that still didn't work. Aside from bypassing the amp, I'm lost as to what else I can try.
Ive been looking around and it does look like you need to bypass it. That just boggles my mind that I've never ever had a problem doing a Ram up until the 07 which needs to be bypassed. Weird... just weird.
