Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Stereo Help
Old Oct 18, 2007 | 08:43 PM
NeonLights's Avatar
NeonLights
Default Stereo Help
OK... i have an after market stereo system in my 96 neon, it stopped working a while ago. I checked fuses, and changed them all, still nothing. I checked to make sure there was power to the system and there is and it is also grounded, still nothing. I rewired in a new stereo, light tested the power supply that hoooks in to the back of the stereo itself is grounded and getting power, but it still isnt turning on. I'm out of ideas... any help would be awesome
thanks in advanced
NeonLights
Old Oct 18, 2007 | 09:10 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: Stereo Help
fuses on the stereo?
Old Oct 19, 2007 | 12:50 AM
NeonLights's Avatar
NeonLights
changed them...still doesnt work
Old Oct 19, 2007 | 01:26 AM
12 volt's Avatar
12 volt
should have one that says batt that keeps info from your head unit when you shut car down, should alwyas be hot. The other main one you should check is the accesory wire, this is only hot when your key is turned to 2nd position
Old Oct 19, 2007 | 01:38 AM
NeonLights's Avatar
NeonLights
yea thats the way it is... its always grounded...and only reads power when the cars on. but hte stereo itself doesnt turn on or anything
Old Oct 19, 2007 | 01:47 AM
12 volt's Avatar
12 volt
try and test the wireing with another goodunit.
me thinks yours is toast
Old Oct 22, 2007 | 12:52 AM
habeba86's Avatar
habeba86
Check a 10 amp fuse(red) in a grey casing in the fuse box under the hood.
Old Oct 22, 2007 | 02:41 AM
marionso14's Avatar
marionso14
did you plug the antenna in? alot of dodges actually use the antenna as a ground and will not cut on without the antenna plugged in to the radio
Old Oct 22, 2007 | 09:40 AM
rtkota5point9's Avatar
rtkota5point9
Not true, dodges use a seperate wire or strap as the ground, most people just don't hook them up and the antenna is then the ground. Maybe on old old ones, but not anything recent.
Old Oct 22, 2007 | 12:31 PM
marionso14's Avatar
marionso14
you are correct and i guess i should have clarified a little, i have worked on several 90's model dodges and earl 00's and alot of the ones i have seen with aftermarket h/u already instaled, they had cut the strap and wondered why it wouldnt work. so i would have torun a seperate ground.
