Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
uconnect
Old May 18, 2009 | 03:26 AM
rns's Avatar
rns
Question uconnect
I don´t know why, but i connected the ucennect, an if a press the face button it doesn´t work. but if somebody calls me goes via mygig and appear in the screen but I only can answer by my phone if i press the uconnect button is appears a legend " it doesn´t have ucnnect" what is the problem?
Old May 22, 2009 | 03:55 AM
72combo's Avatar
72combo
just because the buttons are there does not mean you have uconnect, check your window sticker, if not on there you dont have it.
Old Dec 23, 2009 | 05:36 AM
Siriapp's Avatar
Siriapp
Try this website, this may be what you are looking for... http://www.coastaletech.com/MYGIG_MICROPHONE.htm
Old Dec 24, 2009 | 01:43 PM
rns's Avatar
rns
But the thing is that I do have, I install it myself, it does work only when a calls comes in or out, but not by pressing the buttons.
thanks
Old Dec 24, 2009 | 07:07 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
So you can actually talk through your radio when the calls come in? or does the radio pretty much just act like a caller ID for you?
You can have a radio with the buttons but not have UConnect. Uconnect is a module that plugs into the back of the radio. Then there will be a mic that you would run somewhere near your visor/center console or something.
You say that you installed this yourself, did it have the UConnect module and mic with it?
Old Dec 28, 2009 | 02:08 PM
rns's Avatar
rns
Yes it actually comes through the radio each time I make a call or I recevied a call. It has the mic conected and the UConnect module too.
But it just don´t work botton of UConnect, what coul be the problem?
thanks
Old Dec 29, 2009 | 06:00 AM
Siriapp's Avatar
Siriapp
You said
My thought now is...are you sure that the Button you are pressing is working? Did you buy this new or used? I imagine it is the button on the Mirror, or do you have the little rectangular module? In any case, I think that maybe the button you are pressing is broken OR the wire that you have running to it and your radio is not all the way plugged in.
Old Jan 15, 2010 | 11:54 AM
rns's Avatar
rns
I bought it new, and it has the rectangular little module. It just once work fine, it work suddenly but just once. I instaled and unintaslled a few times so I don´t think is because is not plugged it correctly.
thanks
Old Jan 28, 2010 | 03:04 PM
Belrix's Avatar
Belrix
If you are adding a chrysler uconnect module to a chrysler factory "u-connect ready" radio you will need to take the vehicle to a dealership and have the system activated.
