Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
View Poll Results: A poll
One Sub
22.22%
Two Subs
55.56%
3 or more Subs
22.22%
Voters: 9. You may not vote on this poll
One Sub vs Two Subs
Old Jun 3, 2005 | 03:21 AM
  #21
nickoman01's Avatar
nickoman01
The Only Elite DF Member
Default RE: One Sub vs Two Subs
2 subs, includes subs, amp, and box
$685 120.3dvc
$682 12.1d
$622 1232w
1 sub, includes sub, amp, and box
$426 1232w
$495 12.1d
$457 120.3dvc
best value???
Old Jun 3, 2005 | 03:48 AM
  #22
alpine25's Avatar
alpine25
Heres my last attempt (see embedded picture). Both of those setups would be good, but i would have to reccomend the two perfects for that extra punch.
[IMG]local://upfiles/16833/774EE7DCFFA044C4B7CBA394E12BF03F.jpg[/IMG]
Old Jun 3, 2005 | 03:58 AM
  #23
nickoman01's Avatar
nickoman01
i see so it would be running ti at 1 ohm, which it cant handle, damn it. so i cant run it this way
Old Jun 3, 2005 | 04:07 AM
  #24
alpine25's Avatar
alpine25
Finally, you understand. You can go with two Kappa Perfect 12.1s, which are the exact same speaker just single 4 ohm. Then the amp would see 2 ohms and you would have yourself a reliable and very good sounding system. Let me know if you have any other questions.
Old Jun 3, 2005 | 04:23 AM
  #25
nickoman01's Avatar
nickoman01
OK so if i do the kappa perfect that are single voice coil and wire them up how i had in mind it would recognize it as 2 ohms instead of 4 ohms. so it would be doing 329 at 2 ohms to each speaker.
[IMG]local://upfiles/5543/74C7146B894B4177B2FA45A6C7B27833.jpg[/IMG]
my system would be 2 single voice coil infinity kappa perfect 12.1 running at 2 ohms 329w per speaker on infinity reference 610a amplifier.
Old Jun 3, 2005 | 04:28 AM
  #26
alpine25's Avatar
alpine25
that would be correct wire it like this......
[IMG]local://upfiles/16833/76771771D37A4485AF95AE5D123E3848.jpg[/IMG]
Old Jun 3, 2005 | 04:35 AM
  #27
nickoman01's Avatar
nickoman01
OK i see. it wont hurt the subs running at 2 ohms, even though they are rated for 4 ohms.
the amp does 456 x 1 at 4 ohms
the amp does 657 x 1 at 2 ohms
thanks for the help i really appreciate it
Old Jun 3, 2005 | 04:39 AM
  #28
alpine25's Avatar
alpine25
no it absolutely will not hurt the subs- there are people running 8 8ohm subs for a 1 ohm load, its perfectly fine.
Old Jun 3, 2005 | 02:04 PM
  #29
nickoman01's Avatar
nickoman01
I'm looking at $682.56 for 2 infinity kappa perfect 12.1 subs with the infinity reference 610a, and a box. including shipping and handling, and installation...ill do that myself. i got an amp wiring kit. just need that installed, and the intrepid is a motherf*cker to find a spot in the firewall to go through. we tried passenger side, and ended up in the sub frame.
Old Jun 3, 2005 | 02:33 PM
  #30
alpine25's Avatar
alpine25
That sounds good, stratuses suck for wiring too.
