Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Subwoofer Box
Old Jul 6, 2005 | 04:31 AM
  #31
alpine25's Avatar
alpine25
Default RE: Subwoofer Box
ohhhhh you want two
just double the width of that box +.75 for the seperator, or build two of them
Im too tired to mess with paint anymore lol
And if your getting two you will need two of those amps or one better one.
Old Jul 6, 2005 | 04:49 AM
  #32
Natedogg625's Avatar
Natedogg625
I threw ths togrther in like 1 minute on paint, this is what i was going for, it also has the dimensions of the box u posted
[IMG]local://upfiles/17790/D32D5EB1BFA3472ABE3A9F198B03CAA7.jpg[/IMG]
Old Jul 6, 2005 | 04:52 AM
  #33
alpine25's Avatar
alpine25
That will be fine, as long as its not slanted, i cant tell from the pic lol
Old Jul 6, 2005 | 04:57 AM
  #34
Natedogg625
The front is slanted a lil bit. and if I were to get one better amp which one would u recomend?
Old Jul 6, 2005 | 05:02 AM
  #35
alpine25's Avatar
alpine25
http://www.crutchfield.com/S-C3aIKD7...9RAA1000&g=130
That will overpower them a little, but they should handle it fine
As for the box, you will need to recalculate the volume if you slanted it, 1.25 is optimal.
Its 2:15 im going to bed i'll be back on tommorrow to help you out
Old Jul 6, 2005 | 05:18 AM
  #36
Natedogg625
may be ill stick w/ the straight front. and whats the difference between 4 and 2 ohms? and which one is better?
Old Jul 6, 2005 | 10:31 AM
  #37
alpine25's Avatar
alpine25
ohms that you want all depends on the amp you are getting. With that amp, you would want to get the dual 4 ohm versions of the sub
Old Jul 6, 2005 | 03:21 PM
  #38
Natedogg625
Would the 2 ohm version of the alpine sub i posted be ok? and would that MB quart Amp be able to power both subs?
Old Jul 6, 2005 | 09:35 PM
  #39
alpine25's Avatar
alpine25
You want the dual 4 ohm if your gonna get that amp....
Old Jul 7, 2005 | 02:39 AM
  #40
Natedogg625
So how many Subs can be hooked up to the MB Quart amp? the RMS on the Alpines is 300W, and the description of the Amp says 250W RMS @ 4 ohms.
