Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Dodge Neon Alternator
Old Sep 8, 2005 | 04:55 AM
03NeonSXT's Avatar
03NeonSXT
Default Dodge Neon Alternator
I'm planning on installing two Audiobahn AW1206T's, 1100 Watts RMS each with an Audiobahn A12001DT amplifier powering both of them. Will I need to buy a high output alternator?
Old Sep 8, 2005 | 02:53 PM
SPANKYSPL's Avatar
SPANKYSPL
Default RE: Dodge Neon Alternator
Sure, why not? Another solution would be an Optima Yellow top battery under the hood and, if still needed, an XSTATIC Batcap in the trunk near the amplifier.
Old Mar 9, 2006 | 07:03 PM
shnormo's Avatar
shnormo
High amp alternators is the best solution. Even if you get a cap and a battery, it still strains your alternator.
Old Mar 9, 2006 | 07:31 PM
highline95jl's Avatar
highline95jl
Higer amprige alternator is the way to go, a battery kit is a waste for the type of system your getting.
Old Mar 10, 2006 | 12:22 AM
car_audio_god's Avatar
car_audio_god
www.mean-green.com
www.h-o-alternators.com
Old Mar 10, 2006 | 04:08 AM
habeba86's Avatar
habeba86
excessive amperage also makes good alts
www.excessiveamperage.com
Old Mar 10, 2006 | 05:28 PM
JLTD's Avatar
JLTD
If the amps were capable of producing that power @ 12.5V, you would need 176 amps of current under abusive conditions with music. The car needs 40 - 60 to operate.
Old Mar 11, 2006 | 03:51 AM
stantheman's Avatar
stantheman
i would go with a higher amp altenator. in my other truck, which was a chevy, i had a 200 amp altenator. i had two 1100 watt memphis amps and 4 12's in the bed. also had two batterys under the hood also. which might be an option for you. if you go with a yellow top optima, i would get two and put one in your trunk. they are non-spillable and wont put off harmfull fumes. thats with a higher amp alt. too.
