Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Quick wiring question..
Old Dec 11, 2005 | 01:47 PM
RayDog26's Avatar
RayDog26
Default Quick wiring question..
i was a little confused about how the crutchfield site has there wiring diagram... tell me if the way i plan to do it will work out right. if you understand it lol
[IMG]local://upfiles/8534/B3FF39B45A5D4740A7F0C46CA40CE892.jpg[/IMG]
Old Dec 13, 2005 | 09:46 PM
Techno's Avatar
Techno
Default RE: Quick wiring question..
This gets word complicated fast.
First the picture. The speakers dual coils are wired in series so each speaker is an 8 ohm speaker. Then those TWO speakers are wired in parrallal for the 4 ohm single channel NOTE this is hooked to only one channel so you need 4 of those speakers. You could call this the right channel. The left channel would look just like it only to the left.
You have yours wired in series also so they each are 8 ohm speakers. But your using 2 speakers on 2 channels not 4 speakers on 2 channels. ( or 2 speakers on a single channel).
Assuming the right half of the amp is the right channel you have one single speaker at 8 ohms per channel. This won't hurt anything except you lose some power.
It sounds like you have the wrong speakers. 2 ohm dual voice coils is what you need for 2 speakers on 2 channels at 4 ohms (The coils are also wired in series = 4 ohms). OR you need a 4 channel amp OR you need one more amp - which is like having a 4 channel amp.
If you had normal single voice coils at 4 ohms your wiring would be much simpler. For 2 channels using 2 speakers that is.
Old Dec 14, 2005 | 12:02 AM
alpine25's Avatar
alpine25
Ummm....
Most 2 channel amps that i know of can run at 2 ohms per channel.
Run each speaker in parallel instead of series (+ to +).
That will give you no problems whatsoever.
Old Dec 14, 2005 | 02:55 AM
RayDog26's Avatar
RayDog26
ok i have a 2 channel amp. my subs are 4 ohm so im guessing 2ohm per voice coil since they are dual voice coils. now your saying the best way to wire it is parallel instead of series. so i made this diagram let me know if its right or not. sorry if im a bother im just tryin to learn how to do this right since its my first time and i prefer to not have to use my insurance before i even get to hear them in my car lol (if wiring them wrong would blow them out)
[IMG]local://upfiles/8534/B4B2D42577C14C94AFA9CEC78E9DA607.jpg[/IMG]
Old Dec 14, 2005 | 11:14 AM
bionic4.0's Avatar
bionic4.0
what model and brand subs do you have
Old Dec 14, 2005 | 02:11 PM
RayDog26's Avatar
RayDog26
Infinity 1242w subs
Boss audio rt645 amp
Old Dec 15, 2005 | 05:18 AM
ngsm13's Avatar
ngsm13
Horrible amp...but oh well.
Those Infinity speakers are Dual 4ohm subwoofers.
Therefore, if running off of a 2-channel amplifier...all you have to do is:
Combine both positives and both negatives from one sub, hook the combined wires up to their respective terminal on one channel of the two channel amplifier. Now do the same to the second sub for the remaining channel of the 2 channel amplifier.
A 2 channel amplifier will put out rated power @2ohms per channel...which is how you will be running it.
NG
Old Dec 15, 2005 | 02:08 PM
RayDog26's Avatar
RayDog26
aww why you say its a horrible amp... i read many nice reviews on it and the company is pretty decent itself. and thx for the help on how to wire it up.
