BLown sub?
got everything hooked up and running. door speakers ROCK but the sub sunds like absolute ****. I have the frequencies turned to the lowest on th sub side of the amp but the distortion is awful. cant find any rips in cone or anythin but it sounds like it is ripped in side the cone. SOunds like a bunch of celifane being crunched at once every time it hits. is it blown? or is it something else?
amp is kenwood 8454 4 channel. front channels is pushing a set of door speakers and the rear channels ar runing the sub. its bridged at 200 watts (not a lot of power) and peak might hit a little more but not much. sub is alpine swe 1242 12 inch. rms is 250 and peak is 800 watts or so. Im no where near overloading this sub. im gona try runin it off the front channel to see if it clears up. the setup im using is i kept the stock headunit and conencted the high level inputs for the signal. could this be my problem? all wires check out im just puzzeled. so far its lookin like i eat that sub and get another one. hate to do that though
Trending Topics
Not all aftermarket headunits have pre-amp outputs. And just because you're running 200W to a 250W sub doesn't mean you can't overpower it. And by overpower I mean running a clipped (distorted) signal into the speaker. If your amp clips it can send as much as 4 times as much as it's rated power into the sub. At the same time, the clipped signal is keeping the sub from moving as much as it would when it had a good signal. The extra power, and the sub not being able to move fully makes cooling itself impossible and it cooks.
Like I said I would test it with a meter. If it reads right it doesn't necessarily mean it isnt cooked either. We get these crappy pioneer 251's in all the time that have the same symtoms you say, sometimes they won't even move, but they still read fine on a meter. Like the voice coil unravelled
