Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
JL w3v3... what do you think?
Old Feb 26, 2007 | 03:18 PM
HighDuke1911's Avatar
HighDuke1911
Default JL w3v3... what do you think?
I have extra cash now... and after I sell my Infinity Kappa Perfect 10.1 ($150 or best offer) I plan on getting 2 JL w3v3's. I have an amp that is pushing 338w RMS per sub @ 2 ohms. So I am wondering is an extra 38 watts RMS is too much for a w3 since it's recommended RMS is 300.
Old Feb 26, 2007 | 04:40 PM
squatchie16's Avatar
squatchie16
Default RE: JL w3v3... what do you think?
No, you subs will be completely fine if you install them properly.
Old Feb 27, 2007 | 12:19 AM
HighDuke1911
kool. thanks.
Old Feb 28, 2007 | 08:41 PM
whiteram00's Avatar
whiteram00
you will be fine,38 watts is not goin to hurt anything there,100 watts maybe but not 38,let us know how it sounds
Old Mar 1, 2007 | 04:55 AM
HighDuke1911
ok, kool. thank you. see i dont know what the limit should be/is. so what do you say? up to # watts is the most you should go over the RMS.
Old Mar 1, 2007 | 05:12 AM
habeba86's Avatar
habeba86
Depends on what the sub is rated at to begin with..and what type of enclosure your using.
Old Mar 3, 2007 | 10:23 PM
HighDuke1911
well, the w3 is a 4ohm sub with 300w RMS. the enclosure is the same as the one for my infinity's. not sure on the cu. in. and stuff. ill talk to my installer on the size. and my amp pushes 338w to each sub at 2 ohms. its a 4ohm 676w RMS mono MTX TC6001. so basically all im doing is adding the JL's and ridding of my Infinitys.
Old Mar 4, 2007 | 06:06 AM
habeba86's Avatar
habeba86
I think you will miss those kappa's......
Old Mar 4, 2007 | 11:08 PM
HighDuke1911
why do you say that?
Old Mar 5, 2007 | 12:57 AM
habeba86's Avatar
habeba86
I jst think the kappa's are better than the w3
