500 "plus" horsepower Hemi??
RE: 500 "plus" horsepower Hemi??
Its Pretty cool isn't it? Wanna see a pic of it? https://dodgeforum.com/m_323643/tm.htm
wow that is one powerful engine my freind mike would be like say what are you kiddin? i just have one question i thought dodge was gonna stop the hemi in 2006 cause it was just an anniversary thing at first.. i guess they are continuing it! SWWWEEEEEETTTT!!!!!!!!!!
MY NEW RIDE!
[IMG]local://upfiles/19290/F2BA7D4F03204A27BD1DD29EF8EA0E3A.jpg[/IMG]
MY NEW RIDE!
ORIGINAL: Chryco4Life
Sounds good of course, but Allpar's possible uses for this engine are dumb.
ORIGINAL: nsyncfanatic03
MY NEW RIDE!
MY NEW RIDE!
ORIGINAL: 97 3.5 Intrepid
Could you explain your logic on this? I think having this in the Viper, Firepower, and Heavy Duty Ram would be a good idea. The HEMI would cost less to build than the V10, it is supposed to be less expensive to build than the 360 and the newer 4.7 SOHC. It would most likely get better fuel economy as well because it would be a V8 instead of a V10. This would help lower the cost to build the Viper that Chrysler could use to either lower the price or keep the price the same to improve the profit margin. The Firepower would be more attractive if it had more hp and torque to add to its performance image (since this is the point of this car). The Ram could use a replacement for the V10 in the Heavy Duty models because not everyone wants a diesel. I think it would be good to add this to the Challenger, Charger, Magnum, 300C, Dakota (if it would fit) as well.
Trending Topics
wow, if that was true on the cost of building a hemi (I assume the 5.7?) is cheaper than building a 4.7 engine, Would this be a signal that Chrysler/Dodge will scrap the 4.7 and have the 5.7 hemi as the entry level V8 engine? I know the gas mileage between the two are very close.
ORIGINAL: Kensai
To HemiMan4451, I wouldn't be surprised if they did this with the Viper. It would give them a chance to offer a version that would better compete with the Z06 Corvette price wise, weight wise, fuel economy wise, and performance wise-since the specs appear to be comparable to the V10. If they did this I would bet that they would offer a V10 or at least a engine more powerful than base engine that would satisfy the people that want class leading performance. When the Viper was being produced, the V10 was just one idea that they discussed (as well as the 426 HEMI). I think they could pull it off with something other than the V10. Frankly, I wish they would have used the 426 HEMI when they started so then we could enjoy the option of some of the larger editions of big block HEMI like the 528 HEMI that produces 610 hp & 650 ft-lbs of torque or the screaming 540 supercharged HEMI that produces +900 hp[sm=drooldude.gif].
ORIGINAL: HemiMan4451
I doubt the viper will ever be a v-8. When people think viper, they think big v-10.
Exactly. I could see it in a monster-sized Ram or badass muscle car; but not the Viper, and definately NOT if it was also in the Firepower. Regardless of how cheap the engine would be to build, as soon as you have similar models with similar price and options, you are going to lose money. It's happened before. So, final answer: the Firepower isn't real and Viper is synonymous with V10.
