Dodge Demon Concept - Geneva Debut
Old Feb 12, 2007 | 12:31 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default Dodge Demon Concept - Geneva Debut
http://www.leftlanenews.com/2007/02/...ept-2009-2010/
I dunno about this....looks like a Honda S2000 screwed a 350Z and added in a lil Charger for the front fascia..... That said, it definitely has potential....not to mention the fun factor. It could really help Dodge in the aspect of sales IF it's a popular car, not to mention get rid of the overly expensive and not selling worth a crap Crossfire.
Old Feb 12, 2007 | 12:59 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: Dodge Demon Concept - Geneva Debut
does the slowstice have a back seat?
Old Feb 12, 2007 | 02:59 PM
2coff's Avatar
2coff
Looks like a refresh of the Razer concept, but in a better direction, I think it looks good.What I do like mostis 2600 puunds RWD and 300 HP this thing will fly andhandle amazing just from lack of wieght,I want one.
Old Feb 12, 2007 | 03:06 PM
MoparMJM's Avatar
MoparMJM
ORIGINAL: BadStratRT
nope
Old Feb 12, 2007 | 03:26 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
ok...i wasnt sure...i knew that the S2000 and the 350Z did not...
Old Feb 12, 2007 | 03:46 PM
DCXgageman's Avatar
DCXgageman
Dodge Demon Roadster concept vehicle
Simple soul, artful attitude make for radical results
The Dodge Demon concept is a compact, nimble "roadster with an attitude," a perfect balance of classic sports car proportion and simplicity blended with modern design and performance.
"While the iconic Dodge Viper is a dream car for many, the Dodge Demon is designed to be an attainable dream car," said Jae Chung—Dodge Demon Principal Exterior Designer, Chrysler Group. "The exterior design is simple yet bold, featuring an energetic combination of curves and intersecting planes."
The bodyside of the Dodge Demon main character line flows up and over the front wheel, then drops diagonally to an angular color-keyed vent on the rear fender that directs cooling air to the rear brakes. In similar fashion, the compound rear fender surface curves up and over the rear wheel, sweeping into a broad diagonal plane extending to the taillamp. The resulting muscular fender form projects boldly beyond the main body, underscoring that the Dodge Demon concept is a rear-wheel-drive machine.
The rear surface of the body is divided into three planes with two chamfered outboard planes, dominated by long, tapering trapezoidal taillamps. The taillamps sport translucent red inset lenses that surround LED back-up lamps.
Up front, the signature Dodge crosshair grille is stuffed into an aggressive, menacing, trapezoidal opening that thrusts boldly forward.
Set into elongated angled triangles, the projector headlamps, delineated by bright rings, are set into black chrome bezels, giving the front end mean-looking "eyes" that accentuate the grille opening. Encompassing the upper portions of the front fenders and sporting two recessed air outlets, the Dodge Demon's hood is hinged at the front, adding a just-for-fun performance-car look and feel.
Featuring an open-spoke design, the wheels are pushed to the corners of the body for a dramatic stance and capable performance. The 19-inch brushed aluminum wheels are set into assertive, asymmetrical openings that reprise the body's playful combination of curves and planes.
The beltline kicks up at the rear and into the higher deck lid contour, giving the lucky occupants an encapsulated, protective feeling.
"In the manner of timeless British sports cars, the interior of the Dodge Demon is purposely functional, not frivolous," said Dan Zimmermann—Dodge Demon Principal Interior Designer. "Everything relating to the driving experience is emphasized, while that which is not is made visually secondary.
"The well laid out instrument panel, for example, is familiar, yet modern. Everything you really need—the gauges, circular AC outlets, radio—is encapsulated in a cross-car brushed aluminum bezel that also accentuates the width of the cabin. Secondary controls and features, such as the HVAC ***** and the passenger-side glove box, are located below this bezel," Zimmerman added.
In a similar functional manner, the floor console is deliberately not a part of, or attached to, the instrument panel. The console is dominated by the squat ready-at-hand silver and black manual shift ****, and its leather boot is set into a bright trim ring. The wide, brushed aluminum console bezel also incorporates the recessed emergency brake handle, with the window switch gear, softly lit cup holders and 12V power outlet organized into a graphically unified shape. The upper portion of the instrument panel, including the cluster brow, is accented by a stitched seam with contrasting silver thread.
"Each of these features is set flush, or nearly flush, with the bezel surface so as to establish a 'clear zone' for the driver's shift arm in all seating positions, with nothing in the way of the driving experience," Zimmerman said.
The raised plateau at the rear of the console incorporates a covered storage bin—with a lid that serves as an armrest between shifts—while the portion of the console extending under the instrument panel has an open bin handy for incidentals.
The steering wheel employs an aluminum open-spoke design with each of the three spokes intersecting the small circular hub for a timeless sports car look. The wheel rim itself is brushed aluminum on the inside, complemented with stitched vinyl on the outer rim. Immediately forward of the wheel, the four-gauge cluster features classic white-on-black dials with graphics inspired by sports watches. Each circular gauge is set handsomely inside a finely detailed silver and chrome bezel ring, while gauge pointers are colored to match the exterior.
The doors feature durable, vertical grab handles, each anchored to a silver bezel housing the chrome door remote handle. The lower portion of each door features a stylish brushed aluminum bezel that encapsulates the large circular speaker grille and then drops sharply as it moves rearward to form the map pocket outer panel, mimicking a feature line on the car's exterior.
The Dodge Demon's seats feature contoured bolsters that are just high enough to provide support when cornering, yet do not hinder ingress or egress. Set in exposed low-gloss carbon fiber shells, the black seats with integral head restraints feature inserts of textured "Momentum" fabric mated to fabric bolsters, with specific sew lines accented by silver thread. Individual brushed aluminum and carbon fiber roll bars are positioned directly behind the bucket seats. With long seat tracks, there is ample storage behind the seats. Additional covered storage is provided in the bulkhead between the seats.
The Dodge Demon concept is an affordable Dodge sports car which merges brand cues of bold design and powerful performance with an open-air "fun-to-drive" attitude.
PRELIMINARY TECHNICAL SPECIFICATIONS
Dimensions are in inches (millimeters) unless otherwise noted.Engine: 2.4-liter petrol World Engine
Maximum Power: 172 hp SAE (128 kW) @ 6000 rpm
Maximum Torque: 165 lb.-ft. (224 Nm) @ 4400 rpm
Transmission: Six-speed manual
Drivetrain: Rear-wheel drive
Overall Length: 156.5 (3974)
Overall Width (max. @ body): 68.3 (1736)
Overall Height: 51.8 (1315)
Wheelbase: 95.6 (2429)
Overhang, Front: 30.6 (777)
Overhang, Rear: 30.3 (769)
Curb Weight (estimated): 2600 lbs. (1179 kg)
Tire Size, Front/Rear: 58.7 (1491)
Wheel Size: 19 x 8 in.
Outer Diameter: 25.2 (640)
Exterior Color: Bright Amber Pearl
Interior Color: Carbon Black
(Published Feb. 12, 2007)
Old Feb 12, 2007 | 04:52 PM
Johndcjr1989's Avatar
Johndcjr1989
looks likea fun car to drive, but im not sure how i like the name. its good that they are bringing back some of the old names, like charger and challenger, but adding a modern touch to it. even though the charger doesnt look much like the originals, it still retains some features.this doesnt even resemble a demon in the least bit. i think that this car will do great for dodge if produced, and i wouldnt mind having one, im just not so sure if i like it being called a demon though.
Old Feb 12, 2007 | 05:09 PM
mopar5949's Avatar
mopar5949
JOHNDCJR, You are a MORON! The name of this and every other car in the DCX lineup mean nothing. If you can't get over it, take off the name badge, slap the letters P-U-T-Z on the back and let everyone know what an idiot you are! This is one smart looking car that should sell well and bring some fire back into the Dodge showroom! Love the thing for what it is and shut your mouth! Like my father used to tell me, "It's better to remain silent and have folks think you a fool, then to open your mouth and remove all doubt!"
Old Feb 12, 2007 | 05:27 PM
nickoman01's Avatar
nickoman01
The Only Elite DF Member
i actually like it, except the interior. but with the exterior liek that there is alot of potential in a car liek this. i hope they arent just teasing us and actually have this turn into somehting.
Old Feb 12, 2007 | 05:36 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
its obvious that dodge wasnt trying to reincarnate the demon with this model, but if it does pick up where the razor left off, and there is an SRT model, we could possibly see a low buck, high performance car, which is what the demon was in 1971.
mopar5949, there is no reason to be rude...you could have told him that you didnt like his opinion without being a ***** about it.
