Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
509 cam
Old Jan 10, 2007 | 05:17 AM
mandude's Avatar
mandude
Default 509 cam
does anyone know the numbers on it?
Old Jan 10, 2007 | 05:39 AM
unclemike's Avatar
unclemike
Default RE: 509 cam
Purple shaft?
Old Jan 11, 2007 | 06:09 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: 509 cam
The Mopar Performance purple shaft camshaft is part number: #P4120237
Here are the numbers as advertised:
Duration: 292/292
@0.50": 248/248
Overlap: 76 degrees
Centerline: 108
Lift: .509/.509
Old Jan 12, 2007 | 08:30 PM
fc7gtx's Avatar
fc7gtx
Default RE: 509 cam
I had that cam in my 69 Road Runner years ago. Here's a link to some of Mopars old school cams.
http://victorylibrary.com/mopar/mpcam-tech-c.htm#b
Old Jan 13, 2007 | 03:50 AM
unclemike's Avatar
unclemike
Default RE: 509 cam
Back in the day you could get the 383 hi po camshaft from Direct Connection for $33.00. Not a bad deal to hop up a 361 or two barrel 383. The Purple Shaft cams wern't that expensive either but the quality control was typical Chrysler. Specs and timing varied widely. When Lee Iacoca took over prices started to climb and aftermarket cams became a better value. Cam technology has come a long way since the Purple Shafts cams were made. Unless it was dirt cheap I'd run something else.
Old Jan 23, 2007 | 06:09 PM
mandude's Avatar
mandude
Default RE: 509 cam
I was just looking at the numbers to get a custom grind. it's what a friend has in his dart and it is running good. I have basically the same set up in my 74 Roadrunner, I just have 3 2bbl instead of a double pumper. I still have the stock cam in it (77 fury) and it keeps flooding out.
Old Feb 13, 2007 | 08:50 PM
499coronet's Avatar
499coronet
Default RE: 509 cam
good cam (originally designed by COMP in their very early days for Direct Connection), but make sure that your intake matches. This cam makes power at HIGH RPM! If you want to cruise the streets around 3000, go with the .474 !!
Old Mar 27, 2007 | 05:16 AM
manatlarge2's Avatar
manatlarge2
Default RE: 509 cam
Funny now that i think about a purple shaft cambeing old school...but your right there been out for what 26? 30? years now? And $33 was a lot when you were making $1.65 min wage....I read or heard crane is doing some old school regrinds anything on this?
