Acceleration Shake
Acceleration Shake
truck: 2006 dodge ram 2500 mega cab heavy duty cummins
So guys i got this situation goin on,
under no load when i accelerate i get a bit of a shake and it goes away once i get going. when i have a trailer or any type of load the shake gets big like it shakes a lot but then goes away once i get going? i cant figure it out
The 2500's have 2-piece driveshafts that have a center carrier bearing. i would crawl under your truck and shake your driveshaft where it enters that bearing and see if there is any play. It shouldn't move at all, so a slight clunk and it's bad.
if it's not that, then your torque converter may be the problem. How many miles are on it?
Trending Topics
This sounds like it could be a broken trans/eng mount. How about putting it in gear with emergency and foot brake applied and running the engine up some (power brake). Don't spin the tires but put a strain on the engine and drive train. If the engine is missing under load it will show up. If the engine isn't missing then have someone look to see if a mount is moving. Be careful and don't run over anyone.....
