Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
Headlights work on high beam only
Old Apr 6, 2013 | 06:27 PM
terickson18952's Avatar
terickson18952
Default Headlights work on high beam only
I'm new here today, got on because I just got a 2001 Cummins Ram 2500 and there are a couple of issues. One is the headlights only work when I pull the high beam switch. I currently have to run the fog lights only at night in traffic then switch to the high beams when I can.
Old Apr 10, 2013 | 12:55 PM
terickson18952
Default Update
Thanks guys, after removing the bulbs much to my surprise BOTH headlights had only the low beam filament burned in half. Pain in the *** to change (cut up my hands on the battery hangers- sharp!) but only had to replace the bulbs.
Old Apr 10, 2013 | 12:59 PM
terickson18952
Unhappy 2001 2500 Cummins heater core
I am getting a radiator smell in the cab when the heat or defrost is on and it also gums up my windshield. Do you really have to pull the whole dash, steering wheel column, etc to get to the heater core? It looks like it should be accessible right there under the dash.
Old Apr 10, 2013 | 02:51 PM
Jigabop's Avatar
Jigabop
is the heater core leaking?
pull the blower motor out and inspect it...if it is, then yes you're going to be pulling the dash.
if its not leaking, then look for a leak under the hood.
Old Apr 11, 2013 | 11:20 AM
terickson18952
I don't see any leaks under the hood so I will try dropping the blower next. Thanks!
Old Apr 11, 2013 | 06:27 PM
Jigabop's Avatar
Jigabop
its simple enough to drop out...3 bolts and unplug the fan cord
Old Apr 13, 2013 | 10:50 PM
terickson18952
Thanks! It's not too bad yet but that is easy enough. Someone also told me to ask you if it would be bad for my water system to try a radiator stop leak product, and if so, what brand would you recommend?
Old Apr 14, 2013 | 10:09 AM
briando's Avatar
briando
i just got some of the new blue LED's for my ram, they are amazing. anyone wondering about them as they come down the road, it is so worth it, get on the other side of em and enjoy
Old Apr 15, 2013 | 11:20 AM
Jigabop's Avatar
Jigabop
wonder if anyone has done LED vs HID yet to see which has more light output?
