Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
reverse light condensation, seemingly common?
Old Dec 20, 2009 | 11:16 PM
somenothingness's Avatar
somenothingness
Default reverse light condensation, seemingly common?
It seems I have the oddball issues with my 07 SXT. I noticed about 2 weeks ago that my left tail light was showing signs of condensation. So, after reading some other posts I thought I'd try to dry it out and seal it up. Before, I had condensation in the top left corner and in the reverse light areas, but not so much in the turn signal area. I too out the fixture, the bulbs, and used a hairdryer to dry all traces of moisture from the entire fixture. It was a sunny day with no humidity and I worked fast using some clear silicone sealant around the present seal and bulb areas. I blew a little more hot air inside to make sure and then replaced the bulbs. So, after another day of sunshine and low humidity I notice the reverse light area to be the only spot where moisture had reappeared. I know this light is sealed up and no cracks exist in the plastic. So, that's why it baffles me as to the reappearance of this water.
Yet still, I have this thing about taking a closer look at other Calibers whenever I see them parked. I'm not a Caliber stalker per se, just that I like to compare. But, I have noticed that a lot of Calibers have moisture in the left rear reverse light, and not the right side. Is this common, or am I just noticing it more now that I have the same problem?
Old Dec 21, 2009 | 11:51 AM
somenothingness
Default update to useful information
http://www.caliberforumz.com/showthr...d=1#post154101
I posted in the Caliberforums this same instance. Maybe this is of use to others.
Old Dec 22, 2009 | 11:08 PM
lxman1's Avatar
lxman1
Site Moderator
I haven't noticed any on our 09. It's over a year old now.
Old Dec 23, 2009 | 05:57 PM
somenothingness
The dealer has another on order for me. So, glad I don't drive that much. It's under warranty. 36000/3 years.
Old Dec 24, 2009 | 10:40 PM
lxman1's Avatar
lxman1
Site Moderator
Yeah, ours is a little over 15 months old and has under 9K on it.
