Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
does your left tail light look like a fish tank?
Old Jul 23, 2010 | 02:58 PM
dirtman30's Avatar
dirtman30
Default does your left tail light look like a fish tank?
07 sxt tail light has about two or three inches of water, no visible leaks. any ideas? i keep taking off the light and drying it out, but to no help it comes right back.
Old Jul 24, 2010 | 03:33 PM
lxman1's Avatar
lxman1
Site Moderator
Nope, There is either a hairline crack in the lens that you can't see or the seal is bad between the lens and body of the light.
Old Sep 4, 2010 | 05:41 PM
somenothingness's Avatar
somenothingness
My 07 sxt had the issue in the left rear. I have seen a lot of 07s with the left tail light having condensation. The left side was manufactured by a different supplier than the right. I got mine replaced under factory warranty before it expired, which ran out in April 2010.
Old Sep 12, 2010 | 10:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-041-06, DATED
SEPTEMBER 27, 2006, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS
A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT
REVISIONS.
SUBJECT:
Exterior Lamp - Lens Fogging
MODELS:
2006 - 2008 (CS) Pacifica
2006 - 2008 (DC/DM) Ram Truck - Cab & Chassis (3500/4500/5500)
2006 - 2008 (DR/DH/D1) Ram Truck - Pick-up (1500/2500/3500)
2006 - 2008 (HB/HG) Durango/Aspen
2007 - 2008 (JK) Wrangler
2006 (JR) Stratus/Sebring
2006 - 2007 (JR27) Sebring Convertible
2007 - 2008 (JS) Sebring/Avenger
2008 (JS27) Sebring Convertible
2007 - 2008 (KA) Nitro
2006 - 2007 (KJ) Liberty/Cherokee
2008 (KK) Liberty/Cherokee
2006 - 2008 (LX/LE) 300/Magnum/Charger
2007 - 2008 (MK49) Compass
2007 - 2008 (MK74) Patriot
2006 - 2008 (ND) Dakota
2007 - 2008 (PM) Caliber
2006 - 2008 (PT) PT Cruiser
2006 - 2007 (RS/RG) Town & Country/Caravan/Voyager
2008 (RT) Town & Country/Caravan/Voyager
2006 - 2008 (WK/WH) Grand Cherokee
2006 - 2008 (XK/XH) Commander
NUMBER: 23-035-07
GROUP: Body
DATE: August 08, 2007
DISCUSSION:
Some customers may report that on occasion, vehicle exterior lamp assemblies are fogged
with a light layer of condensation on the inside of the lenses. This may be reported after
the lamps have been turned on and brought up to operating temperature, turned off, and
then rapidly cooled by cold water (such as rain, or the water from a car wash). Lens
fogging can also occur under certain atmospheric conditions after a vehicle has been
parked outside overnight (i.e., a warm humid day followed by clear cool night). This will
usually clear as atmospheric conditions change to allow the condensation to change back
into a vapor. Turning the lamps on will usually accelerate this process.
A lamp that has large amounts of water droplets visible on most internal surfaces indicates
a problem with the lamp sealing that has allowed water to enter the lamp. In this instance,
the customer is likely to report that moisture in the lamp is always present and never
disappears. A lamp that exhibits internal moisture permanently should be replaced.
Old May 29, 2011 | 05:34 PM
Trebacz's Avatar
Trebacz
Default Fixed my 2007 Dodge Caliber's tail light leak
I fixed my Caliber's tail light assembly by silicone sealing it around the outside. The link goes to my blog, where I show pictures of how I did it. Been six month's since, no more fish tank look!
Old Jun 1, 2011 | 07:22 PM
lxman1's Avatar
lxman1
Site Moderator
Thanks for the link.
Old Mar 18, 2016 | 08:46 PM
Mango Daytona's Avatar
Mango Daytona
Eventually the "Lamp Out" will require replacing the $15 grey lamp holder which contains a circuit board that will short out due to the water.
Old Oct 26, 2016 | 11:00 AM
Saundrar's Avatar
Saundrar
My 2010 Dodge Caliber has water leaks (floorboards are wet) and the right rear taillight looks like a fishbowl. The taillight has been repaired but still collects moisture. My car is in the shop for the 3rd day now trying to fix the manufacturing defect water leak issue. I think Chrystler should pay for this repair.
Old Oct 26, 2016 | 11:56 AM
DodgeCares's Avatar
DodgeCares
Hi Saundrar,
I'm sorry to hear about the water leak you're experiencing. Since your basic factory warranty has expired, do you have an extended warranty on your vehicle that might cover the repair?
Kori
Dodge Social Care Specialist
