Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
CVT Trans Issue TAKE A LOOK AT THIS!
Old Feb 21, 2014 | 01:56 PM
tim_cleav's Avatar
tim_cleav
Default CVT Trans Issue TAKE A LOOK AT THIS!
okk, so my friends owns a 2007 Dodge Caliber 2.0L with cvt automatic transmission.. last night he calls me to rescue him, because he's on the side of the road and his car wont move anywhere... so anyways we get the car home, and whats happenening is the transmission oil temp light (the planet gear with temp gauage inside) was blinking really fast and all the PRNDL lights were blinking and they all had boxes around them. also when you put the gar into reverse the car clunked really loud and didnt want to move at all.. I forgot my OBD reader, and it was pissing rain.. so i told him I'd come back today and look at it. he calls me this morning and says the car is fine..
can anyone explain this? is this an intermitant issue? will it return? whats the problem?
thanks
Old Feb 22, 2014 | 12:24 AM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum
I would still scan for codes to see what was going on. Might have a shop check the fluid, as it doesn't have a dipstick and uses special fluid.
Old Feb 23, 2014 | 02:55 PM
tim_cleav's Avatar
tim_cleav
nope car was not fine.. when he did put it in gear it started acting the same way again..
so basically the car has these DTC's
P0171 - System too lean bank 1
P0172 - System too rich bank 1
U0101 - Lost communication with TCM
U0402 - Invalid data recieved from TCM
P0131 - 02 sensor low voltage
anyways Im thinking it might be thee TCM, can you buy a new one and install it or does it have to be flashed, etc? also where is the TCM located, i found a module located under the dash, with two plugs going in it, a grey and white.. with about 15 or so wires in each plug, is this the TCM? 2 bolts hold it in place? I'm positive it is... thanks
Old Feb 23, 2014 | 02:56 PM
tim_cleav's Avatar
tim_cleav
pictures would help! thanks!
Old Mar 1, 2014 | 02:46 PM
lxman1's Avatar
lxman1
Site Moderator
It is integrated into the PCM that controls the whole car. I will have to look at our 09, but it should be under the hood.
Check all of your fuses. Also check all of the connections at the battery.
A new PCM will have to be flashed to the VIN to work properly.
