Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Intake Manifold Sensor?
Old Apr 11, 2015 | 07:51 PM
Bob1313's Avatar
Bob1313
Default Intake Manifold Sensor?
SO took her 2008 Caliber 2.0L to AutoZone today to have codes read.
She came home and told me that the Intake Manifold Sensor was dirty or faulty.
Can somebody give me a little more direction than that?
Old Apr 16, 2015 | 07:18 PM
lxman1's Avatar
lxman1
Site Moderator
Do you have the actual code that it has?
Old Apr 16, 2015 | 08:43 PM
Bob1313's Avatar
Bob1313
Unfortunately, I do not. I will try to get her to stop at Autozone next time she gets to town.
Old Apr 17, 2015 | 09:38 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
The short runner valve is reacting to the plates binding inside the intake plenum. It likely won't strand her. If you have powertrain warranty still, it cover replacement of the intake.
Try to find a cheap generic code reader of your own so you don't have to deal with Auto Zone screwing with your car and selling you parts that you don't need.
Old Apr 17, 2015 | 09:30 PM
Bob1313's Avatar
Bob1313
Default Intake Sensor
I spent the last forty+ years working on heavy equipment, and do not recall any plates in the intake manifolds, only inter-coolers.
Sounds like the intake manifold needs to come off. Is that correct?
Old Apr 18, 2015 | 10:16 AM
TNtech's Avatar
TNtech
Old Apr 18, 2015 | 10:22 AM
Bob1313's Avatar
Bob1313
Not quite sure what I'm supposed to be seeing in the manifold illustration.
Old May 3, 2015 | 12:22 AM
lxman1's Avatar
lxman1
Site Moderator
If I am correct, the manifold has dual runners. Long ones for low end torque and short ones for power above around 3500rpm. The flaps open and close to direct the air thru the runners that the PCM want depending on power needed.
Old May 3, 2015 | 07:56 AM
Bob1313's Avatar
Bob1313
OK I think I got it. Understand and have built tuned exhaust in the past, makes sense the engineers would do the same on the front end.
I'm guessing if it is not a bad sensor, the moveable plates in the manifold might be binding. If they are binding, I'm guessing a manifold replacement would be required to solve the problem.
Many Thanks
Old May 3, 2015 | 04:34 PM
TNtech's Avatar
TNtech
Many Thanks
In theory, you could maybe take the intake off an clean the crap out of it and it may work again.
We haven't been down that road in the shop environment as it would cost a customer too much in labor and it would be cheaper to replace the intake. As I recall they do have some little bolts holding the plate assembly in. Of course you have to take the actuator off first.
