Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
cool zone AC vent slide problem...
Old Sep 4, 2006 | 09:05 AM
caliberlover07's Avatar
caliberlover07
Default cool zone AC vent slide problem...
In the cool zone there is a small vent slide at the top out of site that you slide to make the cool air come into the cool zone when the AC is on. Is anyone else having a problem with a loose vent slide? It seems like it slides back after every bumps. Recently I resorted to puttiong duct tap there to hold it open so air can flow through.
Old Sep 4, 2006 | 09:34 AM
DarkHorse's Avatar
DarkHorse
Default RE: cool zone AC vent slide problem...
I think most of em are the same![sm=bustedsign.gif]
Old Sep 4, 2006 | 10:42 AM
bigtsr's Avatar
bigtsr
This thread has been on numerous times since the first Caliber was sold,my car was bulit June 22/06 and it too had the same thing with the door closing whenever you applied brakes.
You can play cat and mouse with your dealer to have repaired or you can take a piece of foam self adhesive weather stripping and place it so the door pulls over it it,this will stop the door from closing by itself.
A number of owners have removed the door completely.
Old Sep 5, 2006 | 02:54 AM
ejfb1029's Avatar
ejfb1029
There is a TSB (Technical Service Bulletin) on a factory fix for the sliding coolzone door.
Old Sep 5, 2006 | 04:58 AM
caliberlover07
ok. do you have the link to the bulletin? I guess it wouldn't hurt to just remove it.
Old Sep 5, 2006 | 06:05 AM
ejfb1029's Avatar
ejfb1029
Here you go:
24-005-06 06/14/2006 2007 PM Chill Zone Does Not Stay Cold Or Chill ZoneMode Door Does Not Stay In Position
Old Sep 5, 2006 | 12:08 PM
TUNDRA_schumacher's Avatar
TUNDRA_schumacher
Old Sep 5, 2006 | 04:45 PM
ejfb1029's Avatar
ejfb1029
Nope can't use duct tape, remember, that is the ONLY thing Duct Tape isn't good for, ducts. Hahahahahahahahahahahahaha
Old Sep 7, 2006 | 07:32 AM
caliberlover07
haha worked for mine
