Rack and Pinion issues
Old Feb 27, 2008 | 02:00 PM
scout15246's Avatar
scout15246
Default Rack and Pinion issues
I took my van to the shop today and was told that my rack and pinion system is leaking and needs to be replaced. I was wondering if knows of any particular causes or manufacturer issues with that unit. The van is an 05 Grand Caravan
Old Feb 27, 2008 | 04:25 PM
vlmuke's Avatar
vlmuke
Default RE: Rack and Pinion issues
I would get a second opinion as being 2-3 years old doesn't sound right for it to be leaking not that it is impossible but not very common are you losing PS fluid? might be coverd under the warranty depends on the milage
Old Feb 27, 2008 | 11:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you still have powertrain warranty? If so its covered. And yes its a common problem with the mini vans.
Old Feb 27, 2008 | 11:35 PM
onephatcracka's Avatar
onephatcracka
its not uncommon. i know they are on back order at the dealer. hopefully they are changing them so they don't leak.
Old Jun 3, 2008 | 08:18 PM
obert's Avatar
obert
How hard is that thing to get out on an '05? Mine's not leaking, but I think the innner tie rods are getting loose.
