2002 dodge caravan se transmission problem??
Old Mar 1, 2008 | 09:25 PM
dylanzachgabby's Avatar
dylanzachgabby
Default 2002 dodge caravan se transmission problem??
My wife drives a 2002 dodge caravan se, when she brakes or coast down to about 30 mph the van seems to jump. It has about 77k. Do you think the transmission is going and is there any other way to tell thats what the problem is...Could it be low on transmission fluid??? Is this an expensive fix... any help would be greatly appreciated...
Thank you.
Old Mar 2, 2008 | 10:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 2002 dodge caravan se transmission problem??
Have you ck the fluid? and isthe ck engine lite on? You can try a service 1st and see if that helps, also there a flash update on the tcm for a 2-1 down shift. Ck with the dealer on the flash, it maybe coverd under or emission waranty.
