Auto Unlock
Old Mar 30, 2008 | 11:03 AM
Tropicalcats's Avatar
Tropicalcats
Default Auto Unlock
Just purchased a 2002 Dodge Caravan Sport and have a question about the auto unlock feature.
The auto door lock feature works fine and I see in the manual how to enable and disable that feature however on the auto unlock it says in the manual to enable and disable the auto unlock feature to refer to the overhead Console customer programmable feature section but I do not see and info on the auto unlock feature in that section.
How do I have the doors auto unlock when I put the van in park? Can I have just the drivers door unlock?
Old Mar 30, 2008 | 02:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Auto Unlock
The auto door locks when the van reaches 15 miles an hour, then locks. But you are asking about the key fob, then you need a DRB3 to program the locks to open just driver's door 1st or all doors.
Old Jul 13, 2009 | 11:06 PM
DreamlandAV8R's Avatar
DreamlandAV8R
I don't know if MasterTech just can't read or what, but I'm having the same problem that TropicalCats is having so if anyone has any info, please send it along to me.
The owners manual tells you how to enable and disable the auto LOCK.. which works fine.. that's not the issue. For the auto UNLOCK.. the manual tells you to look at a section in the manual that doesn't even exist! I read the whole manual forwards and backwards, twice, it's not there.
Old Jul 14, 2009 | 10:30 PM
master tech
Then maybe send the page you are reading. or maybe pictures. Scan the page on your scanner and email to me or post it. And if you don't the answer you are getting, go to the dealer....
Old Mar 31, 2010 | 05:30 PM
boyesreef's Avatar
boyesreef
i have a 2002 caravan se. me van has the auto lock. now the manual says you turn on the auto unlock via the overhead council, i do not have an overhead council. is there any way to turn on the feature without it?
Old Apr 1, 2010 | 12:38 PM
Tizzy1's Avatar
Tizzy1
Prior to the '06 model year, if you do not have the EVIC overhead console, the only way to activate the feature is with a scan tool
Old Apr 2, 2010 | 11:09 AM
boyesreef's Avatar
boyesreef
ok, thats what i thought. ill have to make a date with my dealership.
Old Sep 25, 2010 | 03:09 PM
birchy's Avatar
birchy
I'm having this same annoyance with my GC.. I do actually have the EVIC overhead console though. Can someone tell me how to do the programming change? I still haven't gotten myself an owners manual...
Old Sep 25, 2010 | 05:02 PM
Mikeywndsrf's Avatar
Mikeywndsrf
I have a 1997 Dodge carravan. I'm the one with the dinnging noise all the time. Any who. My keyless entry works and the master unlock and lock system works BUT only the front dorrs and rear door., Not the two sliding doors.. I tried the IOD fuse and still have the same problem. The good news is I fuigerd out where the dinnging noise is coming from..
Old Sep 26, 2010 | 01:21 AM
master tech
It could be the door ajar switches causing the dinging and the lock actuators could be the other problem with the locks.
