Trouble code help
Old 07-23-2008 | 11:47 PM
brteter's Avatar
brteter
Default Trouble code help
P0351 and P0353 Ignition Coil A Primary/Secondary Circuit Malfunction
Has any one else had these codes show up and if so what is the common fix?
I amthinking it is the coil pack but I am not exactly sure how to test it.
Any thoughts?
03 Dodge Grand Caravan
Old 07-25-2008 | 10:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Trouble code help
Sure it could be the coil pack, but also be an open driver circuit wire or shorted. ASD relay could cause some problem as well. You can try a coil pack and hope it works.
Quick Reply: Trouble code help
