radio bug
Old Sep 3, 2008 | 03:19 PM
valyster's Avatar
valyster
New Member
Default radio bug
i installed a new radio( old but new for me) with CD, a deh p3300 from pionner to replace the original radio cassette on my caravan 2000. plugged the wire with diagram i have found, all seems well, all work well, til i turn my light on. then i loose all sound on the radio, but i can see it still working, just no sound. If i want the sound back need to turn off car..then turn on, any1 can help me with this?
Old Sep 5, 2008 | 11:08 PM
master tech's Avatar
master tech
Site Moderator & Tech
What kind of speakers do you have? Because the speakers that came with the van may have amps, build into the speakers. The new radio maybe loosing the 12 volt feed to the amps. Or you may want to reck your connection.
Old Sep 6, 2008 | 09:01 AM
valyster's Avatar
valyster
New Member
i have the original speaker, so dunno if there is an amp on em, but i know that on the orginal radio there was a wire specially for amp, that i dont need for the new pioneer radio
i read on a forum that i should plug the constant 12v on the 2 wire that needed volatge, n leave the switched wire from the car unplugged, guess ill try that.
I also tried to completley deplug the illumination wire from the radio, without any change on the result
Old Sep 6, 2008 | 11:42 AM
valyster's Avatar
valyster
New Member
oki i checked the +12v switched n constant, wire, they still have +12v when i put my light on..tried to connect directly the radio on the battery...problem still there..i prolly have an amp apart of the old radio, having a wire in the back of the old radio, inscribed amp on it...tried to grnd it..no effect, tried to connect it to an external amp wired on the new radio...still no sound, is there a way to disable the amp if they r directly on the speaker?
tks
Old Sep 6, 2008 | 01:54 PM
master tech
what was wrong with the old radio?
Old Sep 7, 2008 | 07:32 AM
valyster's Avatar
valyster
New Member
nothing was wrong, except that it only have cassette, i n wanted a CD
