speedo signal lights and all gauges not working
I just had the same issue with my 02 Grand Caravan. I was attempting to install LED tail lights and blew some fuses. It turns out the HAZARD fuse in the IPM relay box under the hood will be your culprit. Just look at the diagram on the back side of the cover to locate it. I believe it is to the upper left if you are viewing from the drivers fender side. Hope that helps!
Hazard Fuse was the key
I had this same issue with my 2002 Caravan. I had been troubleshooting this for a long time. All Fuses tested fine with a test light. Kept digging after you guys had mentioned the Hazard fuse. Removed the battery, and flipped the fuse box up. Found the ground wire had corroded and rotted off at teh connector. carfully removed contact from the wire harness connector, and soldered a 3 inch jumper wire on. replaced and connected to the original wire. Guages and signal/hazard lights are now working perfectly. Thanks for your help I had originally thought I would have to disassemble the dash and start from front to back, as I would not have assumed the hazard fuse would control the cluster!
Trending Topics
The Dude is correct !!
Same problem. No gauges, turn signals or flashers were working on my 2001 Caravan. Also the chime was fainter than normal. As per many other forums I pulled the instrument cluster but didn't see any problems. Was about to go to the wrecking yard for a BCM. Then saw The Dude's post above. It was exactly as he said. I removed the battery and flipped up the IPM fuse box under the hood and low and behold the wire going to the HZD fuse was corroded away. I did the fix as the Dude stated and all is well !!! Thank you Dude.
Same Problem and Solution
Yippee!!! I had the same problem and solution as the dude78 and who905. It is amazing when you flip over the fuse box and find the same wire broken at the connector. It looked exactly as the picture that who95 posted (thanks-it helped).
One tip is to clean the connector with fine sandpaper or a wire brush so that the solder will work better.
I had my gages go before, but that time it was a faulty instrument cluster which was fixed when I swapped one from the wreckers. I had no other electrical problems. This problem was different because all these things did not work (instrument cluster, turn signals, hazard switch, and headlight chimes that go on if headlights are left on when key is taken out of ignition). Thanks everybody. The internet is sure useful sometimes.
EDIT: Everyone I've ever fixed only had cracks on the ribbon cable socket joint(s). But it takes like 20 minutes to desolder all of them then solder with better flux core solder. In addition I also hot glued the socket before desoldering to make sure it never happened again.. Pulling out the board takes 1-2 hours, probably the same with 4th gen.
Basically hot glue the socket, and solder all the ribbon cable socket joints and you'll never have to touch it again, if it's a cracked solder joint..
