98 Gr Caravan Trouble Codes - suggestions?
Old Dec 1, 2009 | 02:26 PM
snyperj's Avatar
snyperj
Default 98 Gr Caravan Trouble Codes - suggestions?
2 weeks ago I replaced the transmission shift solenoid because it was leaking badly. Since the replacement, no leaks and van has been running great... as good as I can ever recall.... until today. Wife said it lurched badly on the highway and the service engine light came on. Scanned it with an OBDII scanner and I have
P01776, P0734, P0700
Suggestions?
'98 Gr Caravan Sport SE, 3rd transmission.
Old Dec 1, 2009 | 03:42 PM
circumventor's Avatar
circumventor
3speed? them #'s are tranny probs so yall really need to get on a scanner to see trans comp stuff. what yall shuld do is just do a google search and find better info on what it means. i did and come up with tons of posts like on this site too
Old Dec 1, 2009 | 04:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
P1776 LR latched in low, P0734 gear ratio error in 4th gear. P0700 just to let you know you have transmission codes. NO its not a 3 speed, he stated this is their 3rd transmission. You need to have a scanner to perform a clutch test and ck CVI's.
Old Dec 1, 2009 | 06:53 PM
92dak5.24x4's Avatar
92dak5.24x4
If you have gone thru 3 transmissions, either you are doing something wrong or you have some pretty crappy rebuilders or you're buying junkyard transmissions.your codes are related to the shifting control. But the only way to determine the problem is with a proper scanner (as stated) and having someone that knows how to determine (diagnose) the problem, cause, and correction
Old Dec 1, 2009 | 08:07 PM
snyperj's Avatar
snyperj
Thanks Master Tech, your info is useful as usual.
92dak5.24x4 - I have seen other posts by you...why do you even post- just to increase your count?. You added nothing that wasn't already stated and you make assumptions that aren't valid. The first and second transmissions were replaced under warranty from 2 different dealers in 2 different states. The third one is now 2 months out of warranty and Chrysler just says "sorry." So I am doing what I can to try to squeeze a little more life out of it without putting a fortune (which I don't have) into it, so go pound, pal.
Old Dec 2, 2009 | 08:24 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Take a breather guys... just relax. Heated discussions are acceptable, anything above and beyond that take it to PMs (Private Messages) please Thanks all! I hope everyone continues to enjoy DF!
Old Dec 2, 2009 | 08:36 AM
circumventor
idk seems pritty odd to go thru so many trannies in such a short time but if yall get on a scaner and see whats up, then itll be ezr to get her figgured out. or id just toss in another sol pack. them codes shur point that way
Old Dec 2, 2009 | 09:32 AM
snyperj's Avatar
snyperj
I guess if you call 11 years a short period of time, yeah.. but my understanding is that these transmissions have a history, pre 2005. I'm not a mechanic and don't pretend to be- I am just a father of 3 and i can't afford to pay the dealer for every single hiccup and burp that our cars have, so I do what I can and I am willing to spend whatever of my own time I need to in order to save 95/hr labor rates from the local dodge stealer.
As for the solenoid, yeah maybe the one I just put in was bad too, I guess it happens. Everything was good for 2 weeks and then the surge yesterday, the MIL and the codes appeared.
I cleared the codes and drove for about an hour last night and nothing has returned. I am going to double check the electrical connector on it (the solenoid pack) because as I was scouring the net for more info last night I noticed someone mentioned that and it made me remember that I did have a 'slight' problem getting that connected on the new one... I couldn't find where I had put down the 8mm socket , was rushing because it was getting dark and wound up using a wrench.. maybe, just maybe it didn't seat properly, surely it wasn't torqued to spec. I forgot all about that when everything seemed fine, initially.
Anyway my apologies to the group if I was out of line, this van is just been so incredibly frustrating.
Old Dec 2, 2009 | 11:52 AM
circumventor
idk about 11yr 3 trans. a coworker has a 97 gcv with 270,000 miles and never had a trans. my 97 is at 194k on the orig trans. mabye the prob is that high price atf4. i dont use it and i dont have probs
Old Dec 2, 2009 | 10:48 PM
transguy37's Avatar
transguy37
We have seen this alot.If you just replaced the solenoid pack and have a P1776,replaced the pack again,it's the number one cause of this code.
