Low Oil Engine Light
Old Dec 15, 2009 | 06:29 PM
92dak5.24x4's Avatar
92dak5.24x4
Wow, mir and that hill-billy must be related based on the quality spelling. I just had a 1994 Dakota 3.9 v-6 come thru today. It had a flickering oil light and on solid when stopped. First thing I did was install an oil pressure gauge. When cold it had a solid 70psi. As I drove it and warmed up oil pressure dropped. @ 60mph it had 30 psi, but when I stopped, it dropped to 4psi. Definitely a bearing clearance problem, tomorrow the guy needs to decide what he wants done.
Old Dec 15, 2009 | 06:41 PM
mir's Avatar
mir
So I change the Oil and Oil Filter and a oil pressure unit.
Light still comes on
Now I wouldn't have to reset the PCM for this do I ?
Old Dec 15, 2009 | 07:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
The problem may not have been the switch, but something else. Oil pump, pick up tube or a sponed bearing. That is why you want ck the oil pressure first with a gauge,before replacing parts. No you don't reset the PCM. One other thing you can try, cold weather you may try lighter wieght oil.
Old Dec 15, 2009 | 08:51 PM
92dak5.24x4
Lighter weight oil will cause the light to come on earlier. No matter what weight oil you have, when the engine is hot, you'll still have a light issue... therefore you'll be going right back to post #2. And the PCM has NOTHING to do with the idiot light.
Old Dec 16, 2009 | 02:25 AM
mir's Avatar
mir
I dumped the oil out from oil filter into my plam to see if there is any metal parts, but there was none!
Oil is lite weight 5w-30 (for Toronto Winter)
It is time plug a oil pressure guage or a shop
Old Dec 16, 2009 | 06:20 AM
92dak5.24x4
You will only see metal if the engine is knocking. What about the filter you already took off before you changed the oil?
Old Dec 16, 2009 | 11:37 AM
circumventor's Avatar
circumventor
ya i seen shot cam barrings cause good presur cold no presur hot and no metel in the filter
Old Dec 21, 2009 | 01:36 AM
mir's Avatar
mir
Lightbulb
Well, I drove to a dealer. Light came on for 10 sec on up hill at 1500 RPM @ 30 KM/h. Spoke to a Master Mechnic over there. He said he can two thing plug a pressure guage or I can keep a eye on Temp guage see how it goes. After 1K change the Oil and oil Filter again!
I am going to do that and also I am going to keep a eye on oil dip stick for every 100 KM for next 1K miles
On last change I did look at oil in oil filter (fram ) look okay to me (dirty thoug)
Old Dec 21, 2009 | 06:16 AM
92dak5.24x4
Huh, the mechanic says to put on a pressure gauge.. that sure sounds familar. The Temp gage has nothing to do with this problem, nor will it reflect any issue with the oil problem.
Old Dec 21, 2009 | 01:35 PM
mir's Avatar
mir
Question
So what should I do ? have him plug the oil pressure guage or just let it go
since it is [i]NOT[i/] coming on ?
