Coolant & Serpentine Belt
Old Jan 14, 2010 | 02:59 PM
bh758's Avatar
bh758
Default Coolant & Serpentine Belt
I am having my water pump replaced in our 05 SXT Caravan. It was leaking and was getting coolant all over the serpentine belt. They said I should get the belt replaced as well. Is this necessary?
Any info would be appreciated.
Thanks,
Brian
Old Jan 14, 2010 | 04:24 PM
Tizzy1's Avatar
Tizzy1
No, only if it is worn and starting to crack. Only if it was saturated for a long time would it make noise. Only your first water pump?
Old Jan 14, 2010 | 07:10 PM
master tech's Avatar
master tech
Site Moderator & Tech
If the fan belt has been soak with coolant, yes replace it or you will have a belt noise.
