2003 Caravan overead console light
Old Jan 17, 2010 | 08:23 AM
hs545's Avatar
hs545
Default 2003 Caravan overead console light
One of the bulbs in my overhead console lights has stopped working, how do I open it to replace the lamp? It is one of the tap lights.
Old Jan 17, 2010 | 05:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
A small flat blade screw driver and be careful to pry the cover down.
Old Jan 18, 2010 | 08:18 AM
hs545's Avatar
hs545
I apprieciate the reply, can you provide a little more detail? Do you mean pry the tap light cover and from where the right left, top bottom. Where is the the catch located?
Old Jan 18, 2010 | 09:46 AM
92dak5.24x4's Avatar
92dak5.24x4
Pretty rare for the 'bulb' to fail as it's a LED type. Fuse 14 runs it. to remove the CMTC it looks like there is one screw at the front of the unit then it says to just pop out as there are clips that secure it into the housing. just to ask a totally stupid question, did you verify that it's actually on. there's a button which can turn off the unit or toggle thru the different features such as fuel milage, DTE, etc
Old Jan 19, 2010 | 05:30 AM
hs545's Avatar
hs545
There are two map lights, one works, the one on the passenger side doesn't. Don't know what is wrong yet need to get inside to look. I assume there are powered as a pair, if so then the fuse would not be the problem. I can turn the left light on and off by pressing the cover switch, the right side does not work at all. Will take another look tonight. Thanks.
Old Jan 19, 2010 | 08:43 AM
92dak5.24x4
those lights you just pop out with a screwdriver. There are other 'lights' in the overhead console... my bad was under the impression you meant something else.
Old Jan 19, 2010 | 12:22 PM
Tizzy1's Avatar
Tizzy1
you pry the lens down where it pivots and slip it out. The bulb and socket are one piece. The surface where the bulb makes contact will probably be burnt so clean it before putting in a new bulb and bent the contacts of the new bulb up away from the socket so better contact will be made.
