Heater stopped working last night
Old Feb 16, 2010 | 10:31 AM
DanK5's Avatar
DanK5
Default Heater stopped working last night
Coming back to Memphis from Mardi Gras last night I noticed the heater wasn't blowing hot anymore. The engine temp never wavered at all. The AC seemed to still kick in- Any thoughts on what it could be?
05 Grand Caravan STX 3.8.
Thanks,
Dan
Old Feb 16, 2010 | 10:39 AM
master tech's Avatar
master tech
Site Moderator & Tech
Is there anything coming out of the vent? If its not blowing on any speeds, maybe the motor is no good. If its blowing something out of the vents, then ck the coolant level.
Old Feb 16, 2010 | 11:40 AM
DanK5's Avatar
DanK5
Yes, all speeds of the blower work fine. What it blows isn't hot though. I'll have some time Friday to look at this better. Be good to get some ideas of where/what to check first.
Thanks.
Old Feb 16, 2010 | 03:30 PM
Tizzy1's Avatar
Tizzy1
normal '05 coolant leak areas are the water pump, look from the rear of the motor from underneith, the rear heater lines were recalled for a leak so if the recall was done, not an issue, check the radiator, some issues with tank seem leaks.
Old Feb 16, 2010 | 05:16 PM
DanK5's Avatar
DanK5
I just learned of the recall on the heater hose clamps undernieth so they have not been dealt with. Now as I write this I do recall a couple of weeks ago when my wife parked on our slightly sloped driveway overnight there was a long wet spot (3-4 feet) under it. This happened twice and so when I changed the oil last I looked and looked and felt and touched everywhere it could puddle and found nothing. I'm not even sure where under the van it was leaking from (front, rear, drivers, passenger side) I just noticed it after the van was moved. I kept my eye on the garage floor for days afterward but it never leaked again. Apparently parking on a slight slope allows something to leak from somewhere. I will check the rad seams and pump area. The van has 106k on it now.
Thanks, Dan
Old Feb 19, 2010 | 11:27 AM
DanK5's Avatar
DanK5
Van is at the dealership today to get hose recall taken care of. It was leaking under the right rear. They told me the water pump is also leaking so i guess I'll be replacing that and the thermostat tonight. Can anybody tell me if I need to get 1 or 2 gallons of the Dexcool antifreeze?
Thanks, Dan
Old Feb 19, 2010 | 01:58 PM
Tizzy1's Avatar
Tizzy1
It takes 2 gallons of coolant, get it premixed or buy distilled water to mix it with, yes it does matter.
Old Feb 19, 2010 | 03:47 PM
DanK5's Avatar
DanK5
Thanks guys. Just gotta getterdone now.
Old Feb 19, 2010 | 05:50 PM
Tizzy1's Avatar
Tizzy1
looks like party at Dan's
Old Feb 22, 2010 | 05:06 PM
DanK5's Avatar
DanK5
Got it all done. New plugs, belt, thermostat and water pump.
